SolaraGuy.com • View topic - Correct tire pressure for 17s, 18s and.......19s!
Postby Solaradude » Fri Oct 10, 2003 12:15 pm
I currently have 225/45/17s on my car and I run 34-35 PSIs.....is it too much? I heard for 17s u need like 32-33 PSIs....
Steve :evilbat:
I will bankroll your poker career!! visit www.instant-bankroll.com
Solaradude
Postby Mole » Fri Oct 10, 2003 12:41 pm
tires vary. it should be listed on the tire side wall. mine is 44 max psi.
but i have 37psi in the front and 40 psi in the rear
Postby WTF?? » Fri Oct 10, 2003 2:04 pm
TRDMole177 wrote:tires vary. it should be listed on the tire side wall. mine is 44 max psi.
Yup id agree with you... it varies
I have mine at 37-38 psi...
make sure you check you psi only when the tires are cold... dont bother after 20mins of driving and then checking... I usually check in the morning when I go to work at 7am
Retired... its been fun Image
WTF??
Postby impactX » Fri Oct 10, 2003 3:48 pm
Rule of thumb: for every inch of rim increase, add 2-3PSI (cold pressure).
impactX
Users browsing this forum: Google [Bot] and 14 guests
