SolaraGuy.com • View topic - Brake light problemo
Postby PEITRUS » Sun Oct 19, 2003 5:23 pm
My parking brake light keeps on turning on for a while and the turns off,and then turns back on and then off, etc etc, all at different times. this usually happens when i am in motion. ive tried lifting the parking brake up and then putting it back down, but it still wont turn off, eventaully it does turn off, but its kinda annoying when it turns on whenever it wants. ive even tried hitting the dash but that didnt help much but hurt my solara's feelings. has this happened to anyone else?...or does anyone know how to fix this problem?
PEITRUS
Postby geminimouse » Sun Oct 19, 2003 5:30 pm
Check ur brake fluids
08 Accord Coupe
99 Solara Sold on 7/7/07
geminimouse
Postby PEITRUS » Sun Oct 19, 2003 8:46 pm
geminimouse wrote:Check ur brake fluids
No its not the brake fluid...it's still full...could it just be an electrical problem?
PEITRUS
Postby geminimouse » Sun Oct 19, 2003 9:29 pm
I had that same problem where the brake light came on and off. The tank looked full but I added a little bit of fluid and the brake light went away and hasn't come back since.
08 Accord Coupe
geminimouse
Postby Mole » Sun Oct 19, 2003 11:16 pm
your brake pads themself may be running low.
Postby impactX » Mon Oct 20, 2003 12:24 am
If it looks full, it may not be, because the fluid holder has both front and back.
Check how much pad is left also.
impactX
Postby Jai_Jai_Binks » Mon Oct 20, 2003 6:53 am
impactX wrote:If it looks full, it may not be, because the fluid holder has both front and back.
^^ What he said....
I know in my celica..i once had the same problem...the resivor looked full...but when i added more dot3 fluid to it..the light went away! If that doesn't work..check your pads!
Postby PEITRUS » Mon Oct 20, 2003 5:04 pm
alright thanks, ill add some more fluid, and probably change the pads too because the kind of screach when i press on the brakes, or can it be that the brakes are just dirty?
PEITRUS
Same
Postby SolaraT » Mon Oct 20, 2003 5:41 pm
I agree. I had this problem and noticed that It would turn on when I would make left turns. Especially in the mornings. I added brake fluid due to it being lower then normal and it went away. LOL I did the same thing at first with the emergency brake! That did nothing but get me more PO! :wink: Good Luck!
2007 VW GTI
SolaraT
Solaraguy need mo power guy
Brake Light Problem Went Away!
Postby solarafan » Wed Dec 31, 2003 6:59 am
My brake light came on intermittently, but eventually it stayed on quite often. I was going to go to the dealership to have my parking brake checked. Following the advice of people on this forum, I filled up the reservoir to the Max level. The light did turn off. The interesting thing is, the fluid level was between the Max and Min levels, but apparently the level needs to be higher.
I just wanted to say how great this forum is!
solarafan
Re: Brake light problemo
Postby solarafan » Sat Jan 29, 2011 6:57 am
My brake light had come on again and I had to top off the reservoir again. The fluid was between the max/min levels, but apparently, the level has to be at the max level in order for the light to go off.
solarafan
Postby 02slera » Sat Jan 29, 2011 8:46 am
i would replace the parking brake shoes.
i did this on my car along with topping off the fluid many months ago and its fine ever since.
i did have trouble installing the new parking brake shoes, it seems they were too thick, i couldnt even beat the rotor with a hammer over these new shoes, the rotors just would not fit over the new shoes (and yes the shoes were adjusted all the way closed and the parking brake handle was in the released position), i ended up having to use the lug nuts to slowly force the rotor over the new shoes. then i drove up and down the street and let the damn things burn until the car rolled like normal (at first it was like driving with the parking brake engaged). after some very nasty smell from the rear brakes (and probably some dangerous asbestos in the air from the shoes) the brakes work great and the light never came back on.
2002 Solara SLE v6
02slera
Postby ThatVietGuy » Sat Jan 29, 2011 8:59 am
*cough*8 year old topic*cough*
ThatVietGuy
Postby 02slera » Sun Jan 30, 2011 1:24 pm
^^^ lol yea but solarafan was part of the discussion in 03 and i think that gives him a pass for the resurrection
2002 Solara SLE v6
02slera
Postby Sol-Toy » Mon Mar 28, 2011 1:45 pm
this probably saved me at least a hundred bucks. I wish I read this before taking apart my calipers and inspecting everything BUT the fluid. My reservoir reads as though it's filled high enough, but i'm going to try topping it off like what you folks have said.
2013 WRX Wagon Premium in crystal black silica - current
2012 RAV4 S - Wife's
2000 Solara 1mz - sold after recording 160k mi
https://www.instagram.com/andygriesemer/
Sol-Toy
