SolaraGuy.com • View topic - 340 whp???
340 whp???
340 whp???
Postby swimshady906 » Sun Oct 26, 2003 4:32 pm
02' S2000 Silverstone
swimshady906
Postby JoeB » Sun Oct 26, 2003 5:41 pm
That my friend is a dreamer. There is NO WAY that car has 340hp to the wheels. That is unless he forgot to mention a LOT of mods. :wink: -JoeB
JoeB
Postby Mole » Sun Oct 26, 2003 7:21 pm
any Tx pps that knows of this car/driver?
Postby krawzyazn » Sun Oct 26, 2003 8:16 pm
i asked him for a dyno sheet no reply :drinking:
Postby onefiend » Sun Oct 26, 2003 9:07 pm
did he call it the "Ultimate Sleeper"? lol
onefiend
Postby happy_aggies » Mon Oct 27, 2003 8:40 am
I am hoping to get a test drive. :wink:
happy_aggies
Postby xXsolaraXx » Mon Oct 27, 2003 8:43 am
Before I get started, my email has changed to alltex55@msn.com. My cell # is (817) 875-0590.
lets all call himi and ask for proof!...and arief let me know how far he is...i might wanna come for that test drive!
moe
xXsolaraXx
Postby GoT_TRD » Mon Oct 27, 2003 1:23 pm
i think ill be in on that test drive too.....
-ChiNo-
R.I.P- 1/4/04 98 TRD Supercharged Camry. Boosted for only 4 days and loved it.
Pix @ http://photos.yahoo.com/mj29277
New ride- 93 SC300 w/ 1JZ GTE Swap
GoT_TRD
Postby Stock Solara SEV6 » Wed Oct 29, 2003 9:59 am
If the stock motor is 200HP (at the flywheel) and he is adding 9 psi boost, the HP at the flywheel will be 200 + 200 x (9psi/14psi) = 328. Assuming you loose 20% through loses in the drivetrain (it's probably more) you would end up with around 260 at the wheels.
Stock Solara SEV6
Postby B_Master_Flash » Wed Oct 29, 2003 1:34 pm
Stock Solara SEV6 wrote:If the stock motor is 200HP (at the flywheel) and he is adding 9 psi boost, the HP at the flywheel will be 200 + 200 x (9psi/14psi) = 328. Assuming you loose 20% through loses in the drivetrain (it's probably more) you would end up with around 260 at the wheels.
I'm interested in your math... HP = StockHP + (StockHP * (S/Cpsi / EngineCompression)) does that give a very accurate estimation? I've always been under the impresstion that the Engine's compression ratio was not DIRECTLY related to the HP.
B_Master_Flash
Postby swimshady906 » Wed Oct 29, 2003 5:25 pm
Thats not engine compression, its air pressure ( 1 ATM). Supposedly at 14.3psi ( i think on the .3) the horsepower is doubled. I think we are 10.5 :1 Compression anyways (11:1 for 4cyl?)
swimshady906
Postby cdssolara » Wed Oct 29, 2003 11:12 pm
swimshady906 wrote:Thats not engine compression, its air pressure ( 1 ATM). Supposedly at 14.3psi ( i think on the .3) the horsepower is doubled. I think we are 10.5 :1 Compression anyways (11:1 for 4cyl?)
I can't comment on the accuracy of that equation. If it's true, doubling the horsepower would only be possible if you could increase the fuel enough to maintain the proper air/fuel mixture. Even increasing the boost to 9psi would require a lot of extra fuel to keep his engine from running too lean and risk blowing it up. I don't see any mention of bigger injectors or a different fuel pump in his list of mods. If this guy really knew what he was talking about, you'd think he'd mention those.
cdssolara
Postby krawzyazn » Thu Oct 30, 2003 8:03 pm
he sent me a dyno sheet how do i post it up?
Postby MGLax13 » Thu Oct 30, 2003 9:17 pm
What kind of file is it?
MGLax13
SolaraGuy Solara13
SolaraGuy Solara13
Postby krawzyazn » Fri Oct 31, 2003 12:16 am
he scanned it
Users browsing this forum: Google [Bot] and 15 guests
