SolaraGuy.com • View topic - Does anyone know why
Postby LuxuriousToy » Mon Oct 27, 2003 9:15 pm
My brake light went out. I went and bought a new bulb, When I was on my way home I noticed the waring light was not on anymore, So when I got home I checked the light it was working, It continues to do this on/off. Anyone know why?
Thank you much~*
LuxuriousToy
Postby MGLax13 » Mon Oct 27, 2003 9:28 pm
This can happen if maybe the bulb isn't all the way in and sometimes it makes contact and sometimes it doesn't.
I can only think of one other cause. Something like this happened to one of my headlight bulbs on my Accord. It would go out, and I'd hit the head light and it would go back on. This was because there was something up with the filament inside. Once I replaced the bulb, I had no problem.
MGLax13
SolaraGuy Solara13
SolaraGuy Solara13
Postby Jai_Jai_Binks » Tue Oct 28, 2003 7:26 am
The bulb could be loose..or there could be a weather change in your area that could have made a loose bulb even looser..and hence the lighting thing. I'd just open it up and check up all bulbs just to be on the safe side.
(also have someone press the brake and check the lights)..cus brakelights are hard to press and visualize from rear end!
Postby MGLax13 » Tue Oct 28, 2003 5:46 pm
Well I'm sure the bulb didn't cost you anymore than like $3, so just change it and see if it still does it.
MGLax13
SolaraGuy Solara13
SolaraGuy Solara13
Postby Yanks0114 » Tue Oct 28, 2003 8:54 pm
Check your brake fluid level, that will trip the warning light
Postby Hsakuragi » Tue Oct 28, 2003 11:20 pm
the light bulb warning light or the brake warning light?
since you said the BRAKE LIGHT went out...
Hsakuragi
Postby Grazi07 » Wed Oct 29, 2003 10:14 am
I had a similar problem with my old Saab, it did that every time it rained. Turned out water was getting into the housing, so check to see if there's a pattern as to when its happening and look at the different conditions at the time.
Team Nex-Gen: The new breed of speed!
Check us out at www.teamnexgen.net
Grazi07
SolaraGuy UConn Guy
SolaraGuy UConn Guy
Thanks for all your help
Postby LuxuriousToy » Tue Nov 04, 2003 8:56 pm
The light went out a few more times then the light stayed out, We replaced the bulb and all is good, Just wanted to say thank you for all your help
:D Lux~~
LuxuriousToy
