SolaraGuy.com • View topic - inside window molding
Postby papa solara » Wed Oct 29, 2003 3:30 pm
inside molding around rear window rattles when driving on rough road,any one having this problem.
papa solara
Postby WTF?? » Wed Oct 29, 2003 4:52 pm
did you try ripping it open and tieing down all loose things like wires?
give it a shot
Retired... its been fun Image
WTF??
Postby Anthony » Wed Oct 29, 2003 5:19 pm
Are you sure its the inside rear molding? It could be the assembly for the seatbelt extender on the B-pillar. Try moving the arm up and down a few times to see if that makes a difference on rough roads.
Anthony
2002 SLE V6
Anthony
Postby all_red » Thu Oct 30, 2003 1:02 am
ya papa it happened to me before, just as solara nytez said, tighten everything.
5-speed V6.
TRD Supercharger.
TRD Short Throw Shifter.
Tokico/Eibach combo.
all_red
Postby Guest » Fri Oct 31, 2003 7:00 am
I had the same noise on my driver side rear window molding. I fixed it by removing the plastic molding and putting paper towels (lots of them) inside the molding and under the headliner. It was trial and error. It didn't work the first time. I just kept adding more paper and moving it around until the squeek went away. It took about 4 times. The trick is the paper has to be packed in tight.
To remove the plastic molding you have to take off the seat belt anchor and the coat hanger hook first. Then just pry of the molding with your hands. It's attached with clips. This will not remove the molding all the way, just allow you to pull down the top side to put the paper in.
Good luck.
Guest
