SolaraGuy.com • View topic - Solara Gauges
Solara Gauges
Solara Gauges
Postby JetEngineSolara » Mon Nov 03, 2003 6:15 pm
Im thinking of ordering a set of gauges of EBAY, but they do not have the TRD sign on them. The face however looks to fit the format of my stock ones. Does anyone no if it is safe to get these. Oh and it says it gives directions on how to install but recommends professional installation. professional installation for a set of gauges?!?!? if you guys could help me out and tell me if i should do sumtin other than the directions give me, it would b greatly appreciated.
JetEngineSolara
Postby TadS » Mon Nov 03, 2003 6:20 pm
Easy to install, even with the poorly translated instructions. Mine have worked well for the last year without any problems.
There is all ready alot of info on these here if you search around. Good luck!
TadS
Postby Grazi07 » Tue Nov 04, 2003 8:24 am
which ones are the most reliable? I've seen the ones that have 7 different settings, and the ones that look almost like VW's wit the blue/red scheme....
Team Nex-Gen: The new breed of speed!
Check us out at www.teamnexgen.net
Grazi07
SolaraGuy UConn Guy
SolaraGuy UConn Guy
Postby krook » Tue Nov 04, 2003 10:45 am
Grazi07 wrote:which ones are the most reliable? I've seen the ones that have 7 different settings, and the ones that look almost like VW's wit the blue/red scheme....
whadya mean "reliable"? as in, like, which ones won't fade, ...? as long as they have a warranty, which most on ebay should have, you don't have to worry about that. i have the reverse indiglo gauges from procarparts.com and it's doin' its job just fine.
krook
Re: Solara Gauges
Postby krook » Tue Nov 04, 2003 10:48 am
JetEngineSolara wrote:Im thinking of ordering a set of gauges of EBAY, but they do not have the TRD sign on them. The face however looks to fit the format of my stock ones. Does anyone no if it is safe to get these. Oh and it says it gives directions on how to install but recommends professional installation. professional installation for a set of gauges?!?!? if you guys could help me out and tell me if i should do sumtin other than the directions give me, it would b greatly appreciated.
you don't need professional installation, unless your all thumbs. :P
instructions to install:
http://www.zer0.info/solaraguy/viewtopi ... ight=#6171
krook
Postby TRD MCV20L » Sat Nov 08, 2003 3:13 pm
where can i get the trd one?
TRD MCV20L
Postby impactX » Sat Nov 08, 2003 5:00 pm
TRD never released anything like that.
Those indiglo stuff will die on you sooner or later. The control module sucks and you can't fix it. Don't rely on warranty, when the indiglo gauges have gone wrong, they will not reply your email hahaha.
impactX
Postby Hsakuragi » Sat Nov 08, 2003 5:10 pm
just stick a mini trd sticker on the gauge if you don't mind the rice
Hsakuragi
Users browsing this forum: Google [Bot] and 14 guests
