SolaraGuy.com • View topic - 17 '' wheels need help
Postby balaklava » Mon Nov 03, 2003 9:43 pm
hi i need to change all 4 tires its cost about 400$ but i so on web wheels&tires package for 499$ its 17'' so i dont know is it ok for 2000 solara SE ,is it gona fit or its need spesial instalation? or they fit just like other normal wheels?please let me know
i found the wheels on www.Wheelmax.com they not nicest but its cheap please let me know thank you
balaklava
Postby TadS » Mon Nov 03, 2003 11:08 pm
I don't think the cheaper packages including the right size tyres there. This will cause you speedometer to be off. You'll need a 215/50 or 225/45. For your tyres, as opposed to the 205/40 they're offering, that tyre is way too small for a big, heavy, car like the Solara.
TadS
Postby FLASH » Tue Nov 04, 2003 5:39 am
I cant even figure out what you're asking...but those tires are much too low profile for only 17s.
==FLASH==
(Sister's) 2011 "Pink Prius"
FLASH
Postby SolaraT » Tue Nov 04, 2003 6:49 am
Yeah thats for civics and smaller compact cars. :2gunfire: HONDA
SolaraT
Solaraguy need mo power guy
Postby happy_aggies » Tue Nov 04, 2003 7:14 am
Ask for the offset, it should be between 38-42.
also whether you can get proper tire size for Solara.
happy_aggies
thanks but....
Postby balaklava » Tue Nov 04, 2003 9:18 am
you sayng 205 / 40 is to small for solara,but now ihave originals 205/ 65 so what is the deferents,so if the wheel is 15'' is ok to have 205/65 but if its 17''then its should be 215/45
please let me know because i have no experiance with this staf
and if its better for me to change from 15'' original to 17'' what deferents its gona make better driving??
thank you again
balaklava
Postby kubi » Tue Nov 04, 2003 10:01 am
A 17" rim has to have a 17" tire. A 15" rim has to have a 15" tire. No ifs ands or buts. With a bigger rim you have to have a smaller tire, otherwise it won't fit.
kubi
Re: thanks but....
Postby TadS » Tue Nov 04, 2003 11:34 am
balaklava wrote:you sayng 205 / 40 is to small for solara,but now ihave originals 205/ 65 so what is the deferents,so if the wheel is 15'' is ok to have 205/65 but if its 17''then its should be 215/45
thank you again
First off the numbers work like this (Width / Sidewall / Wheel Size) Remember that wheels go inside tyres.
The sidewall of the tyre is your biggest problem. On a 205/65/15 the sidewall is 65, while on the 205/40/17 the sidewall is 40. The 15 or 17 are the size of the wheel the tyre fits on. So if I have a 205/65/15 (Stock) I have and overall Diameter of 25.5 in, mean while if I have a 205/40/17 I have a diameter of smaller diameter 23.5 in. Anyway this is bad because it will mess your speedometer up by 8% and also throw off your odometer. You can get away with a few %, but 8 is alot!
The other problem is that with less distance between the rim and the concrete, due to the lesser amount of tyre, you increase the chance of bending your wheel.
There is a formula for figuring out tyre sizes width and sidewall that will tell you what is best, or you can check out the link below. It has graphical examples of what I have tried to explain here, if it hasn't entirely made sense. It also does all the math for you :).
I choose to use a 225/45/17 as it gives me a little more width, but the guys with the 215/50/17s have better protection of their wheel rims.
Check this link:
http://www.miata.net/garage/tirecalc.html
TadS
Postby Guest » Tue Nov 04, 2003 2:56 pm
THANK YOU MAN
Guest
