SolaraGuy.com • View topic - fuse questions
fuse questions
fuse questions
Postby Hsakuragi » Tue Nov 11, 2003 11:05 am
if the panel fuse is using # 7.5, but now I'm using #30 instead, will there be a problem or damage to the car?
Hsakuragi
Postby kubi » Tue Nov 11, 2003 11:53 am
I've been told that you're not supposed to just replace a fuse with a larger fuse if it blows... but I couldn't tell you why for sure. I believe it has something to do with the wiring, anyone care to clarify?
Despite that, I would guess that you'll be ok with that fuse, but maybe someone else can answer this better.
kubi
Postby indiglosolara » Tue Nov 11, 2003 12:01 pm
Basically.. your car was made with specific wiring ampage.. lets say.. you have a 7.5amp fuse it in.. that means that the unit that specific wiring system is hook up to can handle that much load.. if it exceeds it it can damage the unit so the fuse can blow first before getting to the unit itself.. now since you replaced it with a higher amp fuse.. you have a higher chance of blowing the unit that wiring system is hooked up to before you blow the fuse..since the fuse ampage is not to its specifics.
what i would recommend is replacing the fuse with the correct amp so you will not have any electrical problems. also if the wire system overheats.. it can burn you wires and cost more in the long run...
indiglosolara
Solara 2 xB
Solara 2 xB
Postby Hsakuragi » Tue Nov 11, 2003 7:49 pm
here is what i expeienced at the panel fuse right now..
7.5 burnt
10 burnt
20 burnt
30, worked, but cannot use the dimmer.
these are all without any LED bulbs
Hsakuragi
Postby Yanks0114 » Wed Nov 12, 2003 12:55 pm
something is shorting out if you keep blowing fuses. A higher amp fuse is NOT the answer. Check all your connections to make sure you aren't grounding anything out
Postby impactX » Thu Nov 13, 2003 3:51 am
You will blow something else instead of the fuse if you change it to a 30A fuse.
impactX
Postby Hsakuragi » Thu Nov 13, 2003 9:07 am
ya, blow me up from the seat ...but i guess it's ok now, changed to 20 for 1 days seems fine, then change back to 7.5 and it works, it's just so weird. All i need now is a new speedometer.
Hsakuragi
