SolaraGuy.com • View topic - 2000 SE Newbie
2000 SE Newbie
2000 SE Newbie
Postby the_pack_rat » Mon Nov 17, 2003 1:59 pm
Great site, just registered.
Just picked up a 2000 SE V6 with the #5 upgrade pkg(I think).
I have searched and read about quite a few things here within the past month.
One thing that still seems to be a mystery after all I've searched & read, is whether or not my car came with keyless entry(KE), the car only came with one key.
I've found the owners manual(OM) to be very vague about equippment. Owners manuals for american cars for instance, will usually use the words optional or available when discussing equippment that is not standard, this owners manual does not use those terms, which could make one think your car came with everything listed in the manual.
I know the KE was standard issue on the SLE, but I'm under the impression it was optional on the others.
Took the car in for service today, and questioned the service writer about this KE issue. She said the car should have a light on the lower LH instrument panel. The tech said that should only be the case with an aftermarket alarm, & he felt confident the car SHOULD have the keyless and alarm, as it does have the security light in the dash tach.
Per the OM, I tried locking the car while leaving the windows open, to see if anything would happen by reaching in to open the door, and nothing happened.
At this point, I'm still leaning towards this car NOT having keyless or alarm, despite what was said to me by the tech at the dealer.
Anyone have any ideas how to sort out this mystery ?.
The car does appear to have the transponder key, if that makes any difference.
Eric < --- clueless
the_pack_rat
Postby Whatever » Mon Nov 17, 2003 2:09 pm
what's a #5 upgrade package??
Whatever
Postby indiglosolara » Mon Nov 17, 2003 2:21 pm
Hey wrote:what's a #5 upgrade package??
thats what i was wondering too...
do you mean the stage 3 trd package???
indiglosolara
Solara 2 xB
Solara 2 xB
Postby the_pack_rat » Mon Nov 17, 2003 2:30 pm
The below info copy & pasted from -
http://research.cars.com
2000 Solara.
Upgrade Package #5 -
Cloth Power Driver's Seat
Includes 8-way adjustable power. Cannot exceed 33% of 4cyl production.
Radio: JBL 3-in-1 Premium Combo
Includes AM/FM, cassette, CD, metal speaker grilles, 2 Din, with 8 JBL speakers.
Rear Spoiler
Includes a high mount stop lamp.
Power Moonroof
Tires: P205/60R16 AS
Includes 6JJ aluminum wheels.
Perforated Leather Steering Wheel
Map Light
Eric
the_pack_rat
Postby onefiend » Mon Nov 17, 2003 4:23 pm
I thought the only one's with Keyless entry were the SLEV6?
oh and Welcome to the Club, you are one of us now.
onefiend
Postby indiglosolara » Mon Nov 17, 2003 5:29 pm
the_pack_rat wrote:The below info copy & pasted from -
2000 Solara.
Rear Spoiler
Power Moonroof
Map Light
Eric
that pretty how my car came stock.. i have all of the above minus the rim and leather steering wheel. i had the 15" stock SE rims..
indiglosolara
Solara 2 xB
Solara 2 xB
Postby kubi » Tue Nov 18, 2003 12:06 am
I am fairly confident that all Solaras come with keyless entry standard.
kubi
Postby Jackass-Jeff » Tue Nov 18, 2003 12:38 am
00 is when they added keyless on all (I think) Solaras
In 99, not all of them came w/ it. My friend doesn't have it at all! and he has a SE V6, not a 4-cyl. =x
1GR-FE ftw!
Jackass-Jeff
Postby Jai_Jai_Binks » Tue Nov 18, 2003 6:22 am
the only upgrade i went for was the JBL's. Don't know what i was thinking...next time...its gonna be top of the line! But my car came with Keyless Entry! If your buying remotes...buy them from ebay...they are much cheaper! programming is easy (but i had a tought time...and the dealer programmed them for me in the end!)
Postby JoeB » Tue Nov 18, 2003 7:02 am
The little red light in the dash is separate from keyless entry. That light is for the transponder key security. When you put your transponder key in the ignition, the light will go out. Although they are 2 separate things, I"m pretty sure that the 2 came together. If you got the transponder key, you also got the keyless entry. I thought you could call Toyota and tell them your VIN and they could look it up and tell you the options it was purchased with. I'm not sure what you can look for to "see" if you have KE but you can buy a remote from ebay and program it yourself, save a lot of money. -JoeB
JoeB
Postby Jackass-Jeff » Tue Nov 18, 2003 9:22 am
PM Davpak about it. He works at a dealership or something
I have 2 key fobs for sale (2002 though) but I don't think they are compatable.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 2442903002 Here's 1.
1GR-FE ftw!
Jackass-Jeff
Postby Jai_Jai_Binks » Tue Nov 18, 2003 10:28 am
JoeB wrote:The little red light in the dash is separate from keyless entry. That light is for the transponder key security. When you put your transponder key in the ignition, the light will go out. Although they are 2 separate things, I"m pretty sure that the 2 came together.-JoeB
For the longest time i assumed that as well.....upuntill my wife (unknowingly) went to walmart and make a copy of our camry key...and started using that...when i noticed..she told me it's been fine all along...(this is for my gen 4 camry v6 xle tho). Yeah, we do have the security light in the speedo, and do have an alarm in the car...but i guess with her trial we figured it wasn't a transponder key (dealer previously had mentioned otherwise!!).
Postby JoeB » Tue Nov 18, 2003 10:39 am
I just meant that the light had nothing to do with remote entry. The light is the indicator for the transponder key security. I guess the light is there even if you don"t have that feature, weird. I got a flat copy of my transponder key made and it will not start the car. I used to keep it in my wallet in case I locked myself out of my car. -JoeB
JoeB
Postby TadS » Tue Nov 18, 2003 10:44 am
xravexboix wrote:00 is when they added keyless on all (I think) Solaras
I didn't get it, so it must have been 2001? My Viper added it anyway :)
TadS
Postby krook » Tue Nov 18, 2003 11:45 am
best way to tell if you have keyless entry: REMOTE
do you have one or not? simple as that. if you don't call the dealership, tell them your VIN b/c in the end, only THEY would know.
welcome to the boards btw!
krook
