SolaraGuy.com • View topic - A bulb is out and I can't seem to get to it. Help
Postby MGLax13 » Mon Nov 17, 2003 3:48 pm
One of the bulbs in the HVAC in my car has gone out. This is the perfect chance to change them all over to blue bulbs as I had planned. I got al lthe bulbs already but when I took off the knobs and took out those screws behind the knobs, the front didn't just come off like I had read in other places on this board. Then I removed that whole trim peice that has the clock on it and I removed the 4 screws surrounding the HVAC and tried to remove that but it wouldn't come out b\c there are things attached to it that don't come unplugged. Am I missing something here or doing something wrong? :x
MGLax13
SolaraGuy Solara13
SolaraGuy Solara13
Postby Hsakuragi » Mon Nov 17, 2003 4:33 pm
if you having the manual AC, there are two clips on the top.
Hsakuragi
Postby MGLax13 » Mon Nov 17, 2003 5:31 pm
Thanks. How do you get to the light around the cigarette lighter?
MGLax13
SolaraGuy Solara13
SolaraGuy Solara13
Postby Hsakuragi » Mon Nov 17, 2003 5:37 pm
just twist around and it should come out, but i don't think you can change the bulb cuz i don't think they are 2721 and i fudge it up.
Hsakuragi
Postby krook » Tue Nov 18, 2003 11:47 am
MGLax13 wrote:Thanks. How do you get to the light around the cigarette lighter?
take off your entire center console. it pops right off with enough force. try using a panel puller at your local automotive dept. store to pop the clip from behind.
krook
