SolaraGuy.com • View topic - Gas Gauge not working?
Postby Hsakuragi » Wed Nov 26, 2003 1:18 am
I need some help here, after I install a new circut board on the speedometer, it seems like the gas gauge is not working anymore, no matter how many miles i drove, it's just stay at the same level, anyone can help? the good thing is i know how many mile the car runs per gallon on average..but ...yea..help... :cry:
Hsakuragi
Postby Mole » Wed Nov 26, 2003 1:30 am
i think about 340.
not even the reserve light will come on?
Postby kubi » Wed Nov 26, 2003 1:43 am
Did you buy the new one used or new? If you got it used maybe they were selling it because the gas gauge didn't work? Kind of sleezy but you never know!
Please stop humping my car, owner privilege!
kubi
Postby impactX » Wed Nov 26, 2003 3:13 am
Why did you install a new circuit board?
impactX
Postby Hsakuragi » Wed Nov 26, 2003 9:59 am
EVERYTHING OTHER thing is fine, lights working, temp stay normal when normal and cold when is cold, i just replaced the circut board (the green sheet on the back of the speedometer...and i'm using my own one...i tried using different screws, but it's the same...
Hsakuragi
Postby impactX » Wed Nov 26, 2003 11:29 am
I would take out the green sheet and put it back again and make sure all connections are good.
impactX
Postby Hsakuragi » Wed Nov 26, 2003 12:19 pm
actually i did...it's the same...but anyone had experience with this?
Hsakuragi
Postby Hsakuragi » Fri Nov 28, 2003 10:26 am
really no one? :(
Hsakuragi
Postby impactX » Fri Nov 28, 2003 12:35 pm
Nope, why would you replace that thing in the first place??
Why not put the original back in
impactX
Postby Hsakuragi » Fri Nov 28, 2003 2:59 pm
the circut board was burnt
Hsakuragi
Postby Yanks0114 » Fri Nov 28, 2003 5:25 pm
Did you touch the needles at all when u changed the circuit board.
When I installed white face gauges on my friends mustang, the gas needle was put on too hard and it wouldn't move. If thats the case, fill up and then put the needle on lighter
Postby Hsakuragi » Fri Nov 28, 2003 11:13 pm
no, i only change the green board where the light bulbs were..i haven't touch the needle, maybe it's the screw...which i don't think the problem...can someone here works for toyota and ask about it? I'm very desperate on this..thanks y'all
Hsakuragi
