SolaraGuy.com • View topic - could this be a problem?
Postby Astro » Mon Dec 08, 2003 10:40 am
Last night while driving, my brake light came on in the guage cluster. Also, the one on the far left. It has a pic of a car with lines behind it. I thought that one was for traction control, which is something I don't have. Could those lights come on for a warning or maybe it's just a short?
thanks...
Postby impactX » Mon Dec 08, 2003 11:08 am
That light is always on and off for me. I just ignore it since my brakelights are all in working order.
Next time the car starts, it should be gone.
impactX
Postby Jai_Jai_Binks » Mon Dec 08, 2003 11:41 am
Just add some DOT3 brake fluid and see if it makes any difference! And bleed your brakes!
Postby Astro » Mon Dec 08, 2003 12:15 pm
cool thanks, any ideas about that other light?
Postby Grazi07 » Mon Dec 08, 2003 2:47 pm
The pic of the car is prolly an ECU error. Maybe its "detecting" the sensor? I had the same problem with my brake light, and it was just because I needed more fluid
Team Nex-Gen: The new breed of speed!
Check us out at www.teamnexgen.net
Grazi07
SolaraGuy UConn Guy
SolaraGuy UConn Guy
Postby SC V6 » Mon Dec 08, 2003 3:45 pm
the light w\ the car and the lines is a tail light going out... on mine it was my spoiler LED lighting, which turned back on in 3 days, and has been on ever sence.. so... check your tail lights...
later
Scott
SC V6
Postby kubi » Mon Dec 08, 2003 5:42 pm
My taillight light came on while I was making a long trip. I stopped to check it out but there was nothing wrong. After I turned off the car and turned it back on it wasn't on anymore and it hasn't been on since which was probably 4 months ago.
Please stop humping my car, owner privilege!
kubi
Postby Astro » Mon Dec 08, 2003 9:16 pm
Scottv6 wrote:the light w\ the car and the lines is a tail light going out... on mine it was my spoiler LED lighting, which turned back on in 3 days, and has been on ever sence.. so... check your tail lights...
later
Scott
That sounds like it
thanks
Postby Mudd » Mon Dec 08, 2003 10:47 pm
Most likely the other is a coolant light. Check your brake fluid (which I'm 99% sure is the issue - it COULD be a mis-adjusted parking brake too, but I doubt it). Then make sure your coolant is topped off.
This is stuff you should be checking weekly anyway.
Mudd
