SolaraGuy.com • View topic - burnt headlight?
burnt headlight?
burnt headlight?
Postby Grazi07 » Thu Dec 18, 2003 3:53 pm
Hey, I just noticed that my driver's side headlight is out on normal intensity, but when I turn the high beams on, it works.... any ideas? Fuse? Lamp itself?
Team Nex-Gen: The new breed of speed!
Check us out at www.teamnexgen.net
Grazi07
SolaraGuy UConn Guy
SolaraGuy UConn Guy
Re: burnt headlight?
Postby WTF?? » Thu Dec 18, 2003 4:38 pm
Grazi07 wrote:Hey, I just noticed that my driver's side headlight is out on normal intensity, but when I turn the high beams on, it works.... any ideas? Fuse? Lamp itself?
-if you have a Gen 1, the H4 bulb has a dual filament so the high beam may be able to work, but your low beams are toast...
-if you have a Gen 1.5, your high beams are a separate bulb.
basically you have to replace your silverstars... bummer!
Retired... its been fun Image
WTF??
Postby Grazi07 » Thu Dec 18, 2003 5:26 pm
yeah, its a gen 1.... thanks nytez
Grazi07
SolaraGuy UConn Guy
SolaraGuy UConn Guy
