SolaraGuy.com • View topic - ABS Relays, and Heaters
Postby SC V6 » Wed Dec 24, 2003 4:36 pm
I am storing my car, and today I went to start it, and a noticed that the ABS light was on... then I noticed that my CD player wasn;t playing.. and figured that when I hooked the battery charger up to the battery, it blew a few fuses and relays.. the only thing that still is going wrong is that I can't turn traction control off, and can't shift out of park w\o using the hidden button... and my heater and AC doesn't turn on.. now im positive that its the relays.. where would I order these from, and how to make sure they are blown
thanks
Scott
SC V6
Postby Mudd » Wed Dec 24, 2003 9:38 pm
Have your alternator checked (this is becoming a common theme here lately).
Mudd
Postby SC V6 » Wed Dec 24, 2003 10:23 pm
not an alternator.. I had it replaced less than 300 miles ago... its not that.> I hooked up a battery charger to the battery when it was connected to the car... which is why the Relays would be blown... im just wondering the best way to get those ordered
thanks
Scott
SC V6
Postby SC V6 » Thu Dec 25, 2003 10:56 am
ANYONE know where to order Denso Relays other than the rip off Dealership?
later
Scott
SC V6
Postby Mudd » Sat Dec 27, 2003 9:19 am
I'd still have the alternator looked at, since what you're describing is textbook alternator failure.
You can get relays from either a junkyard (remember, this is a Camry- they are not difficult to find), or try Conicelli online. I order Mitsubishi parts there about once a month, they're good people, and cheap.
Mudd
Postby SC V6 » Sat Dec 27, 2003 2:58 pm
problem solved
SC V6
Postby Mudd » Sat Dec 27, 2003 6:08 pm
What was the problem?
Mudd
Postby Coconut » Sun Dec 28, 2003 1:41 pm
My head light ( inside the car ) , the dash clock and the 2 front headlights ( expect the hight beam) are not working, I changed the relay a month ago and after the replacement, everything was working perfectly until a week or so, I started again facing the same problems. Any idea? Alternator problems? :-?
Coconut
Postby SC V6 » Sun Dec 28, 2003 4:38 pm
just some fuses popped..
SC V6
Postby Mudd » Mon Dec 29, 2003 7:22 pm
Well, fuses don't just pop. I'd start looking around for a possible cause.
Mudd
Postby SC V6 » Tue Dec 30, 2003 5:28 pm
I know the reason... and I already fixed it.. I hooked a car charger up to my car, and when I locked my doors, it had a power serge to charge the battery and popped fuses..
later
SC V6
