SolaraGuy.com • View topic - changing tires
changing tires
Postby indiglosolara » Fri Dec 26, 2003 3:54 pm
look behind the side skirt, I actually had a hard time, i have to change my stock tires back on my car and i couldn't fit the jack under my car with it lowered. i had to place some wood and drive over it to put the jack under and i looked behind it. it gave enough space to fit a jack and jack stands. But since you have diff side skirt it can be a diff story...
indiglosolara
Solara 2 xB
Solara 2 xB
Postby HKSV6SLE » Fri Dec 26, 2003 4:27 pm
get onme of those low profile car jacks or take it somewhere with a lift.
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
Postby Mudd » Sat Dec 27, 2003 9:15 am
If all you're looking for is a jacking point, anywhere along the frame of the car on either side will work.
Just don't jack your car up by the engine (oil pan), and be careful around suspension components. Costco carries a nice low profile 3 ton floor jack for $80 or so that may be worth looking into for the home.
Mudd
Postby Mole » Sat Dec 27, 2003 7:03 pm
napa has a nice low pro jack.
