SolaraGuy.com • View topic - help
help
help
Postby xsolara33x » Tue Dec 30, 2003 8:58 pm
Hey guys, I was installing my fake reverse indiglos, i say fake because I bought the ones from ebay that have the 5 and 6 switched, but no worries i'm getting them exchanged for good ones, btu anyways, i was installing them a while back ago and messed up the clock light, dome light, and the door indicator light in your dash that tells you if your door is open while you driving, I don't know what is wrong because I checked the fuse boxes and did not see any blown fuses. Are there any other fuses anywhere? What do you guys think it could be? Any help will be greatful, thanks.
xsolara33x
Postby Hsakuragi » Tue Dec 30, 2003 10:56 pm
take out the coin box, there are more fuses there, refer to your owner's manual and you should find more information.
Hsakuragi
Postby Mole » Tue Dec 30, 2003 11:27 pm
maybe check the plug for the "door ajar." that may be loose.
Postby xsolara33x » Wed Dec 31, 2003 2:03 pm
I checked every fuse box even the one behind the coin box, but could not find any blown fuses. Anyone know what it could be?
xsolara33x
Postby krook » Wed Dec 31, 2003 2:49 pm
it must be a fuse if all 3 of those things are not working. you must have grounded your door wire, which i'm not sure HOW that would even happen. did you hook up the gauges to the green wire on the farthest to the right of the instrument cluster. (plugs on back; right plug as if you were facing the instrument cluster)
krook
Postby kondo » Wed Dec 31, 2003 3:00 pm
how did you get power to the indiglo? If you spliced into it wrong you may be grounding out all of those things. The way I did mine was by taping into the red wire on the back of the odometer. Try unpluging everything and disconnecting your batery.
Nick
kondo
SolaraGuy StickerGuy
