SolaraGuy.com • View topic - What's up with my door?
Postby Missay » Tue Jan 06, 2004 7:24 pm
I'm just curious if I should be worried bout this...it's only happened 3 times now in the past 10months or so.
Tonight, when I got in my car and shut the door it wouldn't shut fully. It was ajar, but closed and I could fit a finger out the side of the window. From the other two times it did it, I knew all I had to do was re-open it and use two hands to slam it closed as hard as I can :lol:
The thing that scares me, is that when it doesn't shut fully it almost looks like the door doesn't fit into the door socket or that the door is unaligned with the door frame.
I know from work that sometime a latch can be messed up, preventing it from shutting, but I don't think that's it. It had snowed, so maybe it was just like when a door jam swells up in the heat and shrinks in the cold? I'm almost wondering if someone tried to slim jim my door cause it looks like the window is bulging out a little where you'd pry the door open :-?
Melissa
Missay
SolaraGuy Ambassador
Postby krook » Tue Jan 06, 2004 8:06 pm
it's not your window that's gettin' caught? i know that was happening with my door. try and check the door latch too.
krook
Postby AzN_DrAgoN48 » Tue Jan 06, 2004 8:23 pm
missy i had the same problem ever since i bought the car. i went to the dealer and the fixed it. it was misaligned. they realigned it and replaced the window molding.
2001 Dark Blue Solara SE V6
8000k Osram HID
Silverstars fogs
Clear Corners
Passport 8500 Hardwired
Two Alpine 12" Type R Subs
JBL BP600.1
AzN_DrAgoN48
Postby Missay » Tue Jan 06, 2004 8:31 pm
ewwww..how much would that cost outta pocket?
Maybe I'll stick w/ the two hands in the side compartment, slam shut method.....that's provided the window doesn't shatter............. :o
Melissa
Missay
Postby AzN_DrAgoN48 » Tue Jan 06, 2004 8:35 pm
lower the window when you close the door it helps. mine was covered under the warranty
8000k Osram HID
Silverstars fogs
Clear Corners
JBL BP600.1
AzN_DrAgoN48
Postby Missay » Wed Jan 07, 2004 10:09 am
AzN_DrAgoN48 wrote:lower the window
you know...it did it AGAIN this morning. I took your advice bout the window, except I lowered the window while the door was still shut and BAM the louded pop scared the hell outta me and the ajar light on the dash went off and the window was sealed....cute.
Melissa
Missay
Postby HKSV6SLE » Wed Jan 07, 2004 2:52 pm
my car has done that before just open and close it a few times it should pop back in. thats one of the minor problems with having a coupe, no "frame for the window"..like on 4 doors.
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
Postby adam2562 » Wed Jan 07, 2004 9:49 pm
lube the lock mechanism.. its good to lube them every 3 months where they catch..
Adam - 99 V6 5spd 165k -SOLD
adam2562
Postby SE4ME » Thu Jan 08, 2004 2:40 pm
two door coupes are notorious for sagging door hinges. The heavy doors sag the hinges with a lot of use. IF the striker pin is not adjustable, you may want to replace the door hinges....or slam the door alot...
SE4ME
2002 SE V6 Red - of course !!
"Ruby"
SE4ME
Postby Anthony » Sat Apr 24, 2004 2:08 pm
Hey Missay,
I think that I have the same problem as you described. Sometimes when I close my door, it doesn't close all the way (i.e. there is a gap). I have to open and close the door several times for it to "fix itself". It seems that the top corner of the window (corner where the seat belt latch is at the B pillar) pushes into the molding. It's almost like the door is too high up as opposed to sagging too low.
Did you ever find a fix for the problem? Anyone have any suggestions?
Thanks,
Anthony
2002 Solara V6 SLE
Anthony
Postby krook » Sat Apr 24, 2004 3:44 pm
damn. anthony get +50 points for searching, as this is definitely a thread from the grave. :lol:
i think missay ended up taking it to the Toyota to have it checked. hmmmm she hasn't posted in a while too...
krook
Postby MalBandito99 » Sun Apr 25, 2004 5:59 am
I got the same deal, with the window hitting that plastic frame outside. I just got into the habit of lowering the window a tiny bit every time I close the door from the inside. When I close it from the outside, it closes correctly.
Funny other people have this problem too, I thought i was the only one. haha
MalBandito99
Postby krook » Tue Apr 27, 2004 7:40 pm
MalBandito99 wrote:I got the same deal, with the window hitting that plastic frame outside. I just got into the habit of lowering the window a tiny bit every time I close the door from the inside. When I close it from the outside, it closes correctly.
nah, this is a totally different problem. i mentioned about the window hitting the plastic molding, too when this problem was first presented back in 1982 by Missay.
we resolved that issue by blaming it on our frameless doors and that we were SOL when it came to the window and plastic molding.
THESE guys are having a problem with their actual door and its hinge. thank god i never had to deal with that shit though....
krook
Postby Solaradude » Tue Apr 27, 2004 8:16 pm
what happeend to missay
Steve :evilbat:
Solaradude
Postby MalBandito99 » Wed Apr 28, 2004 12:14 pm
Ah okay, bro. Misunderstood what was going on.
MalBandito99
Users browsing this forum: Google [Bot] and 10 guests
