SolaraGuy.com • View topic - Rare Solara Convertible
Postby BabyFaceFinster » Sat Jan 10, 2004 8:05 am
Finished today. Headers, Y-pipe, dual rear cat with Magnaflow mufflers with dual rear tips plus one resonator.
1st impression? The low rumble pitch is a little much, almost tough on the ears, but it seemed to have gotten quieter on the 35 mile drive home. Once the computer adjusts, it should quiet down some, I was told. Have to go back to finish the S-AFC, which should allow more tweaking.
Power increase? Not much yet, if any. But I remeber it took 500 miles or so for the initial power kick of the S/C to be fully in effect.
Also Iridium plugs and Magnecor wires. To be further evaluated
Brought the ragtop back. It was too much. It hurt the eardrums.Installed was one baffle and the old resonator from the Toyota factory pipe, which they cut out.
F---ing sweet. The pitch is nice; the rumble is almost perfect. Power seemed to be increasing as the computer adjusts.
The only drawback is at appx 20-35 mph @ appx 1700-2000 rpm, the drone can be a "intrusive" for a bit, but overall, it is bad butt.
Pictures soon of the engine, under the car, and the slick twin-tipped Magnaflow mufflers.
PIX SOON.
One BAD-A$$ rare solara convertible!!!
BabyFaceFinster
Postby Jackass-Jeff » Sat Jan 10, 2004 10:49 am
Once you are S-AFC tuned, you will have nice gains! =D
1GR-FE ftw!
Jackass-Jeff
Postby Astro » Sat Jan 10, 2004 11:17 am
Nice setup. I can't wait to see some pics. That's what I want to do, dual rear cat w/dual tips. :D
Postby cdssolara » Sat Jan 10, 2004 1:07 pm
Sounds really nice. Can't wait to see pictures and hear more about it. Keep us posted.
cdssolara
Postby BabyFaceFinster » Sat Jan 10, 2004 6:13 pm
x rave xboix wrote:Once you are S-AFC tuned, you will have nice gains! =D
have a Apexi S-AFC II, but there is no pinout in the book, so the place that did the exhaust work will open the connector to figure it out. They called Apexi and found out they have not tested the 3.0 engine yet. If I could find out the pinouts from the S-AFC (first model) I'm sure they will be similar.
LENNY
BabyFaceFinster
