SolaraGuy.com • View topic - Extending Wheel Stud
Postby Peter » Tue Jan 20, 2004 10:20 pm
i wanna extend my rear wheel studs. anyone know what size our stock ones are? and anyone know how much they cost? just for the rear. thanks in advance. reason for this is cause i have 3mm spacers in the rear and i just wanna be safe.
Peter's "Black Sheep"
Visit Black Sheep
Peter
Postby swimshady906 » Tue Jan 20, 2004 10:54 pm
Studs are usually pretty cheap. When you think about it its a just a large bolt that is threaded on both ends. If you go through toyota to buy a decent sized 12mm bolt it is like 1.5 dollars so i would imagine at most a stud would cost mebbe 3-4. Good Luck, when u find out let me know because one of mine broke off and ive got to replace it still. :P
02' S2000 Silverstone
swimshady906
Postby Peter » Wed Jan 21, 2004 11:53 pm
bump
Visit Black Sheep
Peter
Postby geminimouse » Thu Jan 22, 2004 3:34 pm
I just changed one stud in the front last week...costed $2 but that's with discount since my brother works for honda. I'll get back to u on the size...
08 Accord Coupe
99 Solara Sold on 7/7/07
geminimouse
Postby Peter » Thu Jan 22, 2004 10:37 pm
thanks
Visit Black Sheep
Peter
Postby Mudd » Fri Jan 23, 2004 8:06 am
If I may ask, why do you need to extend the wheel studs? You get the wrong size wheel or something?
Mudd
Postby Mole » Fri Jan 23, 2004 9:13 am
just the extra precaution from using spacers. i wouldnt mind a set of 10 either if all goes well.
i hear that teh front studs are longer than the rear and the tacoma studs are longer than the front studs of the solara.
Postby Peter » Fri Jan 23, 2004 11:35 am
so u think getting another set of front studs would do? maybe i should ask toyota
Visit Black Sheep
Peter
Postby AzN_DrAgoN48 » Sun Jan 25, 2004 4:43 pm
two of my friends studs broke off (one from each wheel) and we really should get it replaced. can someone do a diy on them with the parts and whatnot? it would really help. thanx
2001 Dark Blue Solara SE V6
8000k Osram HID
Silverstars fogs
Clear Corners
Passport 8500 Hardwired
Two Alpine 12" Type R Subs
JBL BP600.1
AzN_DrAgoN48
Postby geminimouse » Sun Jan 25, 2004 6:46 pm
It didn't say the size of the stud on the bag it came in...
08 Accord Coupe
geminimouse
Postby geminimouse » Sun Jan 25, 2004 6:47 pm
AzN_DrAgoN48 wrote:two of my friends studs broke off (one from each wheel) and we really should get it replaced. can someone do a diy on them with the parts and whatnot? it would really help. thanx
does ur friends drive a solara? it's different for other cars.
08 Accord Coupe
geminimouse
Postby AzN_DrAgoN48 » Sun Jan 25, 2004 7:01 pm
1995 camry so i think it should be kinda the same
8000k Osram HID
Silverstars fogs
Clear Corners
JBL BP600.1
AzN_DrAgoN48
Postby AzN_DrAgoN48 » Thu Jan 29, 2004 8:49 pm
anyone know how to replace a stud?
8000k Osram HID
Silverstars fogs
Clear Corners
JBL BP600.1
AzN_DrAgoN48
Postby geminimouse » Thu Jan 29, 2004 9:47 pm
I've been tryin to get a tutorial together...school just started so i've been busy.
Basically just jack up the car on both sides, take off the wheel and brakes(caliper, pads, and rotors). Get a hammer and knock the stud out. The back protection plate thing has a hole on one part of it. You'll need to line it up by turning the assembly to take the stud out. Then put the new one in and knock it in with a hammer.
This is the instruction for the front studs for a solara...I'm not sure about other cars or for the rear solara studs.
08 Accord Coupe
geminimouse
Postby c2g » Fri Jan 30, 2004 12:32 pm
I didnt even take my rotor off to change one of my front studs i banged it out reached from behind popped the new one in and then used the nut to pull the stud through
99 silverstream SE V6 18" RSL nengans, Streetglow head and fog lights, Reverse guages,
Kicker L7 12" DVC, MTX amp, panasonic 903U, sirius, shaved emblems, clear corners,
altezza tails, K&N filter, mesh upper & lower grill so far
c2g
