SolaraGuy.com • View topic - Flush or not to flush
Postby BabyFaceFinster » Tue Jan 27, 2004 7:14 pm
I am switching to synthetic oil. My engine is clean should I flush the engine first?
LENNY
One BAD-A$$ rare solara convertible!!!
BabyFaceFinster
Postby kubi » Tue Jan 27, 2004 7:41 pm
Don't need to flush it, you can just switch.
Please stop humping my car, owner privilege!
kubi
Postby Mole » Tue Jan 27, 2004 7:42 pm
how many miles do you have on the car?
Postby dan99solara » Tue Jan 27, 2004 8:16 pm
please use german castrol syntec 0w-30 for it is a true synthetic like mobile 1. most of the other claimed synthetics are not 100% synthetic. german castrol does wonders for cold temps and high rpm driving! it is well worth the 4.50 per bottle.
1999 Solara V6 5spd 155k miles
TEIN springs. thats it.
dan99solara
Postby Mole » Tue Jan 27, 2004 8:50 pm
^ what are you? some spokesperson from castrol? :lol:
using 0w-30 oil should only be used in real cold climates, 5w-30 should be sufficent enough.
furthermore, an engine flush has nothing to deal with the motor oil.
this is not a post about which oil to use.
Postby BabyFaceFinster » Wed Jan 28, 2004 5:58 am
TRDMole177 wrote:how many miles do you have on the car?
41k
BabyFaceFinster
Postby Mole » Wed Jan 28, 2004 11:59 am
hmm, thats kinda going towards borderline to switch to synthetic at that many miles. i switched to synthetic at about 10K. if i were you, just stay with normal dino oil.
switching to synthetic at higher mileage may create leaks through the seals. why? i have no idea.
Switching to synthetic oil
Postby SunnySolara » Wed Jan 28, 2004 12:21 pm
I checked out Toyota's web site and they state switching to synthetic oil is OK, as long as the rating of it meets or exceeds their recommendation in the owners manual.
Since there is an engine sludge oil buildup defect with some of the Camry V6s, from 1997-2001 according to Lemon-Aid. it might be a good idea to switch. They say a reduction in the size of the coolant passages in the head gasket can result in the oil literally frying. Synthetic oil can prevent this (I believe it breaksdown at a higher temperature than standard oil). The sympton of this is a white sludge on the oil filler cap or inside the lip of the rocker panel cover.
SunnySolara
Postby Yanks0114 » Wed Jan 28, 2004 12:28 pm
41k should be fine to switch to synthetic. I think its anything over 75k shouldn't be switched.
Postby ericatdallas » Thu Jan 29, 2004 12:53 pm
I read on some pamphlet that it was a myth that switching back and forth between synthetic and dino was bad. I also took an intro class to auto repair and the instructor said the same thing.
Leakage was caused by older synthetics having smaller molecules, but supposedly newer synthetics are better.
My last car I switched back and forth between them in ignorance and started doing it at 90k and drove it for 30k more miles with no prob. Infact, my engine was probably the only thing that was left working when I got rid of it.
2000 Solara SLE V6 - Green w/ Beige Interior
ericatdallas
Re: Switching to synthetic oil
Postby offthahook » Thu Jan 29, 2004 1:18 pm
SunnySolara wrote:Since there is an engine sludge oil buildup defect with some of the Camry V6s, from 1997-2001 according to Lemon-Aid. it might be a good idea to switch. They say a reduction in the size of the coolant passages in the head gasket can result in the oil literally frying. Synthetic oil can prevent this (I believe it breaksdown at a higher temperature than standard oil). The sympton of this is a white sludge on the oil filler cap or inside the lip of the rocker panel cover.
I believe there is a goodwill policy at the dealer where they can put some additive in the crankcase to clean up the sludge that does indeed form...
offthahook
Postby SunnySolara » Thu Jan 29, 2004 5:50 pm
That's good news that you can use synthetic oil in higher mileage engines. I"ll try it in my 1990 Camry 4cyl. which has 90 K on it. Maybe that will stop the puff of blue smoke when you first start it up.
SunnySolara
Postby Mole » Thu Jan 29, 2004 9:40 pm
^ uhhh... now at that mileage i would not recommend the switch from dino to syn for sure
Postby Stock Solara SEV6 » Fri Jan 30, 2004 11:16 am
SunnySolara wrote:That's good news that you can use synthetic oil in higher mileage engines. I"ll try it in my 1990 Camry 4cyl. which has 90 K on it. Maybe that will stop the puff of blue smoke when you first start it up.
Synthetic won't help a problem like that.
2001 V6 5-speed
Stock Solara SEV6
Postby SunnySolara » Fri Jan 30, 2004 12:43 pm
I was hoping it would be white smoke instead of blue smoke. :-?
SunnySolara
