SolaraGuy.com • View topic - engine diag code P1765
Postby SBCelicaGT » Sat Jan 31, 2004 4:24 pm
Does anyone know what the following code means:
P1765: Linear Solenoid for Accumulator Pressure Control Circuit Malfunction
I have a 1997 Avalon engine in my 1990 celica and its mated to a 1999 solara 5spd M/T. The ECU is designed for an A/T so I had to take care of the other DTC's via resistors. However, I have a feeling that this too has to do with the missing A/T but I dont know what its referencing or how I can fix it.
Has anyone else received this code before?
1990 Toyota Celica 1MZ V6
14.7@95mph @ Famoso
All motor. hehehehehe.
SBCelicaGT
Postby Mole » Sat Jan 31, 2004 4:39 pm
whats up adrian! finally made it over here.
badnews... i dont think anyone here has ever expirenced that problem before
Postby adam2562 » Sun Feb 01, 2004 9:45 am
wait so how does that swap work??? the 1mz-fe in the celica... u ever run at the track???
Adam - 99 V6 5spd 165k -SOLD
adam2562
Re: engine diag code P1765
Postby Stock Solara SEV6 » Tue Feb 03, 2004 3:29 pm
SBCelicaGT wrote:Does anyone know what the following code means:
Sure sounds like the pressure controller for the automatic transmission that controls gear changes. Obviously not needed since you have a manual transmission. It's not detecting the circuit and thus giving the code. There's probably a way to add a resistor to the wires that are supposed to go to the solenoid, but we would need some wiring schematics to figure that out.
That's a gutsy swap you have done!
2001 V6 5-speed
Stock Solara SEV6
Postby SBCelicaGT » Sat Feb 07, 2004 7:41 pm
Well, thats just the thing. I have the wiring diagrams for the engine and such, but the only connections in question are the shift solenoids AB and E. These threw the following codes:
P0754 - Shift Solenoid A Electrical
P0758 - Shift Solenoid B Electrical
P0773 - Shift Solenoid E Electrical
So I took care of those using resistors yet this P1765 code still remains. I can get the wiring diagram scanned if you are curious.
14.7@95mph @ Famoso
SBCelicaGT
Postby Stock Solara SEV6 » Mon Feb 09, 2004 7:44 am
Sounds like you know much more about this that me! I assume you have the schematics for the electrical for the car the computer came out of. I assume that it's a computer from an Avalon? If it's not on the schematic, maybe a Toyota tech can help?
2001 V6 5-speed
Stock Solara SEV6
Users browsing this forum: Google [Bot] and 37 guests
