SolaraGuy.com • View topic - performance chip
performance chip
performance chip
Postby Keg-Of-Iron » Tue Feb 03, 2004 1:32 am
What do you guys think of this on eBay!?!.....Is it too good to be true?.....I have seen other resistors but never an actual chip such as this one. It claims to advance timing and adds more fuel. Check it out and send me some of your expert info on this item please. Thanks
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 2458202158
FIGHT ON U.S.C.!!!
2000 SE v6 5spd Supercharged! 6 lb. pulley...
http://www.cardomain.com/memberpage/510493
Keg-Of-Iron
Postby krawzyazn » Tue Feb 03, 2004 2:25 am
waste of $$
Postby Hsakuragi » Tue Feb 03, 2004 2:36 am
i see ur car is supercharged, but if you think those chips are worth the bucks, then why we need supercharger?
Hsakuragi
Postby GR » Tue Feb 03, 2004 5:28 am
Let's assume it's the real deal, but it will still be a waste of money.
The keyword is 'SET'.
Unlike a SAFC, you can't tune with this thing.
That chip naturally isn't for a supercharged car.
In addition it will also increase your exhaust emissions and fuel consumption because of less air per fuel.
If it turns out that your car is running too rich, you'll actually lose engine power, plus messing up your spark plugs as well.
GR
Postby Mole » Tue Feb 03, 2004 7:45 am
this chip has no authentication whatsoever.
This is a chart showing the ECU output reading of the Intake Temperature for a Ford Ranger and Honda Civic.
they dont even show proof for our cars.
(whiteflash, if you're reading this thread do you now see why we are all so negative about chips and resistors?)
Postby Keg-Of-Iron » Tue Feb 03, 2004 10:25 am
alrighty then. Thanks.
FIGHT ON U.S.C.!!!
Keg-Of-Iron
