SolaraGuy.com • View topic - can i fit 19x8.5 on my car.
Postby chinaxb0y » Sat Feb 07, 2004 3:55 pm
can i fit 19x8.5 on my car and what offset is needed ???
chinaxb0y
Postby ICrazyChrisI » Sat Feb 07, 2004 4:17 pm
You'll need some stiff coilovers to have it w/ no problems
ICrazyChrisI
Postby chinaxb0y » Sat Feb 07, 2004 4:33 pm
i have springs though. so does that mean that i can or can't fit 19x8.5
chinaxb0y
Postby ICrazyChrisI » Sat Feb 07, 2004 6:31 pm
Cant, your rim would hit the fender.
ICrazyChrisI
Postby aznNblu » Sat Feb 14, 2004 12:24 pm
Oh man...I was looking at a 19x8.5 rims as well...but since I have TRD springs, the rims will not fit the caR?
2000 TRD Toyota Solara 5spd
aznNblu
Postby ICrazyChrisI » Sat Feb 14, 2004 8:27 pm
Nope, your fender will be sitting on your rim/tire.
ICrazyChrisI
Postby mlimin » Sat Feb 14, 2004 8:56 pm
I have 19x8.5 racing hart cr, no problem at all as long as you get the right offset.I have cut my rear fender.
mlimin
Postby tweazy » Sun Feb 15, 2004 10:02 am
I think schung07 have this setup for is solara. 19 x 8.5 all around but with spacers in the front and he had to shave the rear lip. not sure what the offset is though. most of the guys with 19" I've seen have 19 x 8.
his site:
www.schung07.com
tweazy
Postby ICrazyChrisI » Sun Feb 15, 2004 1:44 pm
Steve also has JIC coilovers on
ICrazyChrisI
Postby chinaxb0y » Mon Feb 16, 2004 5:43 pm
hey mlimin what offset do u have for your rims .... and did u only shave the back fenders ??? or did u roll them ?? did u have to shave the front fenders as well ??
chinaxb0y
Postby mlimin » Tue Feb 17, 2004 12:20 am
I have 38 and 39. I only shaved the rear fender. The reason I have 2 different offset is because I got brembo in the front. For the rear, I wasnt have any problem with that offset untill I replace my strut from bilstein to tokico. So right now I have a custom made 3 mm spacer. for the tire size the max that will fit in there is 225/35/19 only. I have tried so many times to fit in 235, but no luck on it. other than that you should be good.
Masri
mlimin
