SolaraGuy.com • View topic - Everything you ever wanted to know about O2 sensors.
Postby BabyFaceFinster » Wed Feb 11, 2004 5:01 pm
One BAD-A$$ rare solara convertible!!!
BabyFaceFinster
Postby Turbosolara » Wed Feb 11, 2004 10:47 pm
but you know we are using air fuel sensor instead right?
Postby BabyFaceFinster » Thu Feb 12, 2004 6:16 am
Yeah. On certain parts of the car, such as the exhaust manifolds (now headers in my case) But isn't there a O2 sensor after the cat?
BabyFaceFinster
Postby zappa » Thu Feb 12, 2004 5:21 pm
Exactly right,we got'em both....
zappa
Postby Turbosolara » Fri Feb 13, 2004 1:02 am
oh yeah my bad i should check before i reponse.
here we go
California edition: front A/F sensor, back Oxygen sensor
Other state edition: Front oxygen sensor, back oxygen sensor
Postby SolaraT » Sat Feb 14, 2004 9:10 pm
So replacing the sensors is easy huh. Are they expensive? Replacing them even though they are not sending an error code is a good thing simply because of wear and tear a?
2007 VW GTI
SolaraT
Solaraguy need mo power guy
Postby BabyFaceFinster » Sun Feb 15, 2004 12:39 am
UltraslowSolara wrote:oh yeah my bad i should check before i reponse.
here we go
Does that mean the computer is different? I do indeed have a cali edition. If the sensor is different, the signal must be different. If I use O2 sensors in the exhaust manifold, would it work?
BabyFaceFinster
