SolaraGuy.com • View topic - engine check signal
engine check signal
engine check signal
Postby talaznfoo » Mon Feb 16, 2004 5:03 pm
does anyone know how to turn off the "engine check" signal....that stupid yellow signal is pissing me off cuz i went to the shop to have it check out, n they did engine diagnose n said therez nothin wrong wid it, just turn the oil cap tighter datz all, but that stupid signal still wont go away.....
www.cardomain.com/id/talaznfoo
2001 Solara SE, silver, 7 piece TRD kit, 19 Axis TC-Evolution, Eibach Pro Kit, Tokico shocks,reverse gaugages, euro corners
talaznfoo
Postby JoeB » Mon Feb 16, 2004 7:49 pm
Wow, that was a totally lame response from the dealer. Try asking them for more information. If the check engine light is on, there will be a malfunction code. The code is associated with a description. This will tell you what the problem is. When you take a car to the dealer, they usually write the malfunction code on the receipt along with the failure description. It could be that they were correct and the code he saw was related to the oil cap being loose (usually, it's the gas cap). Then when it was tightened, it detected a different problem. You don't want to simply turn it off, your car is telling you something is wrong, you need to fix it. You can purchase an OBD-2 scanner and check the codes and turn it off yourself. Do a search on this web forum and you'll find mention of a couple of them that various members have bought. Most cost just over $100. I bought 1 called Car Codes. They can do more than just diagnostics. They can give you performance info and much more. Good luck. -JoeB
JoeB
Postby adam2562 » Thu Feb 19, 2004 7:59 am
i bet its your charcoal canister.. cuz the scan tool says its sumthing with the fuel .. and so they figure its first ur fuel cap... then when they realise its not that they go to other things it could be... i went thru the same thing b4 i worked there.. but luckily i was working tere when i ordered the charcoal canister
Adam - 99 V6 5spd 165k -SOLD
adam2562
Users browsing this forum: Google [Bot] and 32 guests
