SolaraGuy.com • View topic - tire weight
tire weight
tire weight
Postby Akfahad » Wed Feb 25, 2004 8:12 am
anybody know the weight of the stock rims with tires?
Postby FLASH » Wed Feb 25, 2004 10:12 am
Too much to ship :( I think its around 37lbs? Maybe more.
==FLASH==
(Sister's) 2011 "Pink Prius"
FLASH
Postby Akfahad » Wed Feb 25, 2004 2:14 pm
thanks
Postby cdssolara » Wed Feb 25, 2004 3:26 pm
I think it's more like 44-45 lbs. per wheel/tire. If you use UPS ground to ship, it's not too bad. The bigger problem is trying to protect the rims during shipment.
cdssolara
Postby adam2562 » Thu Feb 26, 2004 8:18 am
i believe it is 37lbs..
Adam - 99 V6 5spd 165k -SOLD
adam2562
Postby JoeB » Thu Feb 26, 2004 8:53 am
Adam, is that 37lbs just the wheel or tire also? Also, is that the 16" stock, isn't there also a 15" with the 16" being the premium?
The reason I ask is I wanted to see how much weight I saved net replacing my 17x7" TRD rims (TSW) and Toyo tires with my new 18x7.5" SSR Comps and Goodyear Eagle F1 GSD3s. The TRDs were 44 lbs and the SSRs were 40lbs. 37 lbs sounds light with the tires. -JoeB
JoeB
Postby cdssolara » Thu Feb 26, 2004 10:28 am
I had the stock 16" rims with Michelin tires. When I sold them I had to ship them to the buyer, so I weighed them by holding the rim/tire and stepping on a bathroom scale. The difference between that weight and my weight was a little over 44 lbs. I think the weight was pretty evenly split between the rim and tire. Joe, the fact that you're saving weight while still using an 18" rim is fantastic.
cdssolara
Postby adam2562 » Thu Feb 26, 2004 12:51 pm
i think it was rim alone
adam2562
