SolaraGuy.com • View topic - Weird noise while driving on freeway
Postby nkx1 » Thu Feb 26, 2004 1:48 pm
I was wondering if any of you would have some insight on this issue before I take my car in-
Last night it was raining kind of hard, and I was driving about 55 to 60 on the freeway with my wipers and defroster vents on. Anyway, I started to hear a low grumbling noise periodically from the engine while driving. It would come on for 20 secs or so, then stop, then a few minutes later it would do it again. It sounded like a Nascar racecar or something, and increased when I hit the gas. I have no idea what it was, and so far this morning it hasn't happened. I had two O2 (or maybe 1 O2 and 1 A/F) sensors replaced a week ago, so does anyone think that it could be related?
Any ideas are much appreciated!
2001 SLE, Diamond White Pearl
nkx1
Postby SC V6 » Thu Feb 26, 2004 1:51 pm
I have had the same thing happen to me... but I thought I was getting water up onto the filter of my injen intake.. but im not sure.. cause it did it also when I had my airbox some. so I dunno.. it would be nice to know what that was
SC V6
Postby RichP » Thu Feb 26, 2004 1:55 pm
it is probably your ac compressor
RichP
Postby SC V6 » Thu Feb 26, 2004 2:08 pm
but I have only heard it when it has been raining out
SC V6
Postby nkx1 » Thu Feb 26, 2004 4:02 pm
I just have the stock intake, so hopefully I didn't get water in the engine. Plus, when I first heard the noise, I pulled off to a gas station to check the air filter. It was dry.
nkx1
Postby Mole » Thu Feb 26, 2004 5:55 pm
RichP wrote:it is probably your ac compressor
right on the dot!
yes, once you turn your defroster on, the car uses the air compressor (a/c) to help defrost the frost on the winshield.
the compressor turns on regardless if the a/c button is pushed or not.
Postby SC V6 » Thu Feb 26, 2004 5:58 pm
but mine has only done it when its been raining out
SC V6
Postby Mole » Thu Feb 26, 2004 6:08 pm
^hmm...
as for you i have no clue.
we're on a level such that weird sounds are normal. i can list dozens of noises that just randomly pop up and go away. unless the CEL or anything goes off, the car is fine.
Postby SC V6 » Thu Feb 26, 2004 6:29 pm
yeah... I would get it to where I would go threw somewhat of some water... and then when I hit the gas it would sounds real loud and would vibrate the whole car... and I checked my short air later, and it was wet.. I think I may have gotten just a little bit of water on so it vibrated and crap.. not quite sure tho
SC V6
Postby SolaraT » Fri Feb 27, 2004 4:48 pm
ScottV6 wrote:yeah... I would get it to where I would go threw somewhat of some water... and then when I hit the gas it would sounds real loud and would vibrate the whole car... and I checked my short air later, and it was wet.. I think I may have gotten just a little bit of water on so it vibrated and crap.. not quite sure tho
Same here. Sounds mostly occured for me when I would go over alot of water. I hit the gas and it almost sounds as if it comes from the floor of the car, like its water getting inbetween the downpipe and the cat. were that meshy pipe is at. This must be a Solara thing for real.
2007 VW GTI
SolaraT
Solaraguy need mo power guy
Postby solara2200 » Tue Mar 02, 2004 3:10 am
hey my car does the same thing. The only thing i could conclude is that it came from the tires picking up too much water. I dont have much traction on them since i have 42,000 miles on the original potenzas. By the way, how much traction do you guys have on your tires. This may be the problem.
solara2200
Postby adam2562 » Tue Mar 02, 2004 7:43 am
u probably dont use ur defroster tho unless its raining
Adam - 99 V6 5spd 165k -SOLD
adam2562
Postby Whatever » Tue Mar 02, 2004 1:50 pm
It happens to my car too. It scared me, cuz I thought it's my engin (I was driving 60mph on a uphill road.) btw I don't have intake on my car.
I think they are right it's the A/C, cuz when that happens my A/C light starts to flash, and it only happens when the weird sound is on.
Whatever
Postby adam2562 » Wed Mar 03, 2004 9:09 am
if ur A/C light is flashing then u need to get it serviced there may be a leak... just to let ya kno
adam2562
Postby Whatever » Wed Mar 03, 2004 1:48 pm
Adam2562 wrote:if ur A/C light is flashing then u need to get it serviced there may be a leak... just to let ya kno
But it only happens once, not even once after that :roll:
Whatever
