SolaraGuy.com • View topic - Remote trunk popper
Remote trunk popper
Remote trunk popper
Postby bfl62581 » Fri Mar 19, 2004 1:46 pm
All,
Does anyone have the part number for the remote trunk popper? I'd like to install this and get the remote key. If I can get this information, I'll put together a DIY.
bfl62581
Re: Remote trunk popper
Postby bronzemaxell » Fri Mar 19, 2004 2:52 pm
bfl62581 wrote:All,
i am attempting to do the power trunk as well, i already bought universial power trunk kit, ebay sell it too for around $12, some aftermarket alarm has trunk release button, i've read the instruction, and the solenoid that pulls the lock open, and to be install near the trunk lock, and leaving existing mechanism untouch.
bronzemaxell
Postby bronzemaxell » Sat Mar 20, 2004 4:51 pm
i've just added the power trunk to my 99 solara, all done by myself but took me 3 hours, and if i have a chance to do the next one, probably take me no more than 30 minutes. i have the aftermarket alarm relaying me a 30AMP wire (12v +) and i ran wire to the trunk lid, drill 2 hole to mount the solenoid, then connect the solenoid pulling cable to the lock mechanism, works beautifully, now i can open the trunk by key, pulling the latch lever on the driver side, or use the remote. i've took a few snapshot of the installation as well.
bronzemaxell
Postby Mudd » Sun Mar 21, 2004 7:44 am
You're looking for a DEI 522T. It hooks up to about any alarm, and needs to be manually installed
http://www.directed.com/security/access/oaccess.asp for more info.
Mudd
yep
Postby mycrobyte » Sun Mar 21, 2004 8:16 am
That is exactly what I installed. Bought the 522T from CC for about 30 bucks. Easy install, works great. Just takes some planning and adjusting to get the selenoid mounted well. Fits under the cover with no problems.
good luck
2000 V6 SE
mycrobyte
Postby Mudd » Sun Mar 21, 2004 9:10 pm
If I may make a suggestion, don't use self-tappers or screws to hold the motor in. Use bolts. It's a bitch to get to, but you won't have to worry about it backing out in a month due to vibration.
Mudd
Postby kronos98 » Wed Mar 24, 2004 10:29 pm
do you need any special tools for the installation?
kronos98
nope
Postby mycrobyte » Thu Mar 25, 2004 5:24 am
you do have a socket set, wrench and basic tools right? other than that no.
I agree with the bolt statement above, that is what I did and used a bunch of loctite on it also.
2000 V6 SE
mycrobyte
Postby WTF?? » Thu Mar 25, 2004 11:56 am
Do you guys have it where it actually springs open?? cuz I know our trunks dont do that
Retired... its been fun Image
WTF??
Postby kronos98 » Thu Mar 25, 2004 4:59 pm
i'm pretty sure it would just act as if you had pulled on the lever next to the driver's seat. there are no springs or any other mechanism to cause the trunk door to fling open.
kronos98
Postby HKSV6SLE » Fri Mar 26, 2004 1:14 am
is it hard to install and wheres a good place to get the solenoid and not ebay.
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
