SolaraGuy.com • View topic - PCV Valve - No Replacement Required?
Postby krzyray » Sun Apr 11, 2004 10:42 am
In the Haynes manual it says to replace the PCV valve every 60,000.
I went to PepBoys and picked up a Purolator PCV Valve (PV1051). This is actually the part number for the V6,
cuz Purolator says: N/R : No Replacement Required for the Breather Element - for the 4 cylinder:
By the way, I took the valve cover off my car, and I'm trying to location where the PCV Valve is. Is it in the hose
coming from the intake?
So the 4-cylinder engine doesn't require the PCV Valve to be changed?
Thanks
krzyray
Postby krzyray » Mon Apr 12, 2004 9:28 pm
miltdoggie wrote:Why did you need to take the valve cover off????
Sorry I didn't mean the valve cover, I mean the plastic cover to the valve cover.
krzyray
Postby krzyray » Wed Apr 14, 2004 1:12 pm
So nobody has the same problem with the PCV Valve on the 4-cylinder as me???
krzyray
