SolaraGuy.com • View topic - Question for the manual tranny guys in here...
Postby dan99solara » Thu Apr 15, 2004 9:02 pm
How many of you have changed your transmission fluid. I have 80k on my car and I would like to do it. I've changed it on other cars, but what gear oil do you all recommend? I saw the mobil 1 synthetic 75w-90 at autozone and I might try that. Any one have any suggestions? thanks!
1999 Solara V6 5spd 155k miles
TEIN springs. thats it.
dan99solara
Postby Fletch » Fri Apr 16, 2004 6:52 am
I don't know what weight, but you must go full synthetic, thats what comes from the factory. I have 110k miles and it's never been changed, I checked it at 100k miles and it looked as clean as if you just opened the quart.
I doubt everybody on the forum would agree but I'm not planning on changing it until the clutch needs replaced.
2006 Legacy GT spec.B
Fletch
Postby pythonjosh » Sat Apr 17, 2004 4:00 am
I've got 64k on my '99 and I agree with not changing the tranny fluid until changing the clutch and resurfacing the flywheel (or dishing out the dough for a lighter flywheel while your at it too). Or at least that's what my plan is. Don't worry about it, unless you're having problems with the transmission.
Later,
Josh
pythonjosh
Postby DavPak » Sat Apr 17, 2004 3:14 pm
drain and fill every 30K is good maintenance. do clutch fluid @ 60K.
'02 Solara S/C'ed V6 5-spd
DavPak
Postby TRD_solaRa » Mon Apr 19, 2004 9:51 pm
DavPak wrote:drain and fill every 30K is good maintenance. do clutch fluid @ 60K.
For real? damn, looks like I still have a ways to go . . . I only have 19,000 on my baby. clutch at 60K seems a long time to . . . peace.
d
TRD_solaRa
Postby adam2562 » Tue Apr 20, 2004 6:46 am
i do mine every 10-15k miles and i use the toyota 75w-90 works fine
i'm gonna start using lucus tho with it
Adam - 99 V6 5spd 165k -SOLD
adam2562
Postby Fletch » Tue Apr 20, 2004 7:29 am
Adam2562 Posted: Tue Apr 20, 2004 5:46 am Post subject:
My roommate read a link from the VWVortex forum about lucus and the results were not good. Suposedly, some dude did a test with the lucus additive and it turned the oil completely foamy. I'll post the link if he can find it.
Fletch
Lucus Additive
Postby Fletch » Tue Apr 20, 2004 7:35 am
Here is this dude's homemade test on the lucus additive.
http://www.bobistheoilguy.com/images/lucas/lucas.htm
Fletch
Postby B_Master_Flash » Tue Apr 20, 2004 11:40 am
wow, I let my friend talk me into putting a quart of that garbage in on my last oil change, dont think I'll be doing that again.
B_Master_Flash
Postby boneezy » Tue Apr 20, 2004 2:06 pm
yeah.. i think my 2nd gear synchros are wilin out on me.. coz whenever i shift from redline in 1st to 2nd.... I get that telltale "ZZ" noise
will changing tranny oil do anything about that?
1999 SE-V6 5spd
160,xxx miles
boneezy
Postby adam2562 » Thu Apr 22, 2004 7:12 am
hmm yea i wont use it either.. no changing ur tranny oil prolly wont.. but they have stuff out there that i believe lessens the wear
adam2562
