SolaraGuy.com • View topic - question about rims and tires package
Postby solaraslev67 » Fri Apr 16, 2004 4:49 am
im buying some exel 18's, i have no idea what the hell these numbers mean except the last number obviously means the size of the rims it fits, the tires i could get r 225/40/18, 215/35/18, 235/40/18, 245/40/18. i plan on lowering my car in the next couple of months about 1.7 inches in the front, and 1.4 inches in the rear. So if anyone could help me, that would be great. Answers will be greatly appeciated ASAP as Im buying rims in the next couple of hours...
Thanks, Eddie
solaraslev67
Re: question about rims and tires package
Postby shidosha01 » Fri Apr 16, 2004 6:54 am
solaraslev67 wrote:im buying some exel 18's, i have no idea what the hell these numbers mean except the last number obviously means the size of the rims it fits, the tires i could get r 225/40/18, 215/35/18, 235/40/18, 245/40/18. i plan on lowering my car in the next couple of months about 1.7 inches in the front, and 1.4 inches in the rear. So if anyone could help me, that would be great. Answers will be greatly appeciated ASAP as Im buying rims in the next couple of hours...
Thanks, Eddie
225/40/18 would be the ideal tire size for your 18' Rims. You could get away with a wider tire like 235/40/18 but that all depends on how wide your rims are and what offset too. Good Luck. 8)
Rizal D. / Forever "tabasco"
99 V6 SE 5spd FT61 1MZ-FTE
393whp/445ft-lbs. TQ @15psi
shidosha01
Postby Jai_Jai_Binks » Fri Apr 16, 2004 8:07 am
My personal exp is that when u buy tire/wheel combo packages. U get a great set of rims (wheels)...but the tires are crappy as hell. I'm not referring to sizing but the brands. This is not just me, but a few friends have also had their 'tire/wheel combo' tires eat up quickly. I agree will talk about rotation/balance/alignment/poressure/how driven, blah blah....
For me this is what I plan on doing in the future: NOT buying tire/wheel combos' surely they save me some money upfront, but in a year i dish out mulla for new rubbers. In the future, iwill buy the rims first, and then buy the tires seperately. At least i can choose my (cough: yokahama's :cough) brand!
Postby WTF?? » Fri Apr 16, 2004 11:30 am
shidosha01 wrote:225/40/18 would be the ideal tire size for your 18' Rims. You could get away with a wider tire like 235/40/18 but that all depends on how wide your rims are and what offset too. Good Luck. 8)
I second that... and if option 2 rubs, you can alwayz roll/cut your fenders... sux to have to do it tho...
Id go with option 1 with shidosha01
Retired... its been fun Image
WTF??
Postby SolaraT » Fri Apr 16, 2004 2:01 pm
You can get 235 as long as your rim is a +38 off set and no wider than 18x7
I got 235 and the speedometer is calibrated closer then with option 1.
2007 VW GTI
SolaraT
Solaraguy need mo power guy
Postby WTF?? » Fri Apr 16, 2004 2:24 pm
solarat wrote:You can get 235 as long as your rim is a +38 off set and no wider than 18x7
Does the width of tires affect the speedometer?!?!
Not that I know of...
WTF??
Postby Jon11582 » Fri Apr 16, 2004 3:10 pm
Thanks, Eddie
http://www.tirerack.com/tires/tiretech/general/size.jsp
Just a little brief on what the numbers on tires mean. Poke around on tirerack to find out anything you want to know about wheels and tires.
First number is width of tire, second number is the ratio of the width to the hight of the sidewall.
235/40/18 is a little taller (4mm) than 225/40/18, so itll be slightly different on the speedometer.
2000 Black Solara SE
Jon11582
Postby SolaraT » Fri Apr 16, 2004 3:21 pm
Actualy I used this link I found in the "Web Links" section...
http://www.1010tires.com/tiresizecalcul ... ion=submit
The calculation came out to be better with the 235 width.
Diameter Difference of only 0.36% from my stock wheels.
I had 205/65/15 wheels when stock.
With the 225 the difference was 1.61%
2007 VW GTI
SolaraT
LOWERING question
Postby SmokInDaSolara » Sat Apr 17, 2004 3:32 pm
Sup fellas! I need some help. I got new 18's with tires 225/40/18 for my 2001 solara and I plan on lowering it with Tein S-tech springs with a 1.7 (front) and 1.4(back) drop. I got a heavy subwoofer in my trunk that kinda lowers my rear. Has anyone ever experienced tire rubbing from the back due to lowering and a heavy subwoofer? Give me some insight please!! I really want to lower my solara but only if it doesn't rub alot. thanks
SmokInDaSolara
Postby SolaraT » Sat Apr 17, 2004 4:01 pm
start a new post. That is off topic. you'll get more response. Also use the search function.
2007 VW GTI
SolaraT
