SolaraGuy.com • View topic - Question about tire aspect ratio
Postby Delshin » Sat Apr 17, 2004 7:02 am
16 inch rims on the solara with 205/60/16. I would like to be able to put on p nero's 205/45/16, but do not fully understand the aspect ratio of height to width. Is the 45 number just a lower height so I would drag on the ground with those tires or what? Calculator for tirerack just offers the 205/60/16 option. *shrug*
Do not want to have to buy new rims yet (hopefully) just want a decent all season tire.
Delshin
Postby SolaraT » Sat Apr 17, 2004 7:52 am
http://www.1010tires.com/tiresizecalcul ... ion=submit
You will be traveling at 60mph but your speedometer will read 66.2mph
Unless you can recalibtate you're speedometer I don't recomend it.
2007 VW GTI
SolaraT
Solaraguy need mo power guy
looked for that post too, thanks
Postby Delshin » Sat Apr 17, 2004 8:26 am
Seeing the visual really helped out, thanks. Now to see if the 225/55/16 are just to wide and would hit the fender wall turning, only a .24% diff but I think to wide :(
Delshin
Postby Mole » Sat Apr 17, 2004 9:56 am
this all depends if you are lowered or not.
personally, just go to 215/55/16. that's what i did and the tire was already starting to look odd.
