SolaraGuy.com • View topic - FInally DISABLE DRL's the right WAY
Postby whiteflash » Tue Apr 20, 2004 6:58 pm
I took it to this guy who is amazing with electronics and he had to go under my steering wheel and he found the Daytime running light relay and cut into the ignition wire because the DRL was linked into the ignition so whenever i turn the car on the lights come on automatically so he had to re-wire it so now i can control my Lights it is incredible!!!
there aren't any directions on how to do it though... wrong forum in DIY
Injen w/CAI Extension
Vogtland Springs
Tokico Struts
Custom Full exhaust
TWM Shortshiftter
8000K HID Kit
whiteflash
Postby all_red » Tue Apr 20, 2004 7:11 pm
There was an easier way of disconnecting the sensor on the dash so you can control 'em and the plug in the upper right side of the engine bay to disable 'em.
5-speed V6.
TRD Supercharger.
TRD Short Throw Shifter.
Tokico/Eibach combo.
all_red
Postby whiteflash » Wed Apr 21, 2004 6:58 am
i trid that gray plug and the night time senser and it didnt work so then this guy went in my car took out under my steering well we found the relay it says DRL on it and then we fixed it from there
Vogtland Springs
Tokico Struts
Custom Full exhaust
TWM Shortshiftter
8000K HID Kit
whiteflash
Postby MalBandito99 » Wed Apr 21, 2004 12:57 pm
I just unplugged that gray sensor in top right engine bay and it worked. Easier.
MalBandito99
Postby ICrazyChrisI » Wed Apr 21, 2004 7:25 pm
MalBandito99 wrote:I just unplugged that gray sensor in top right engine bay and it worked. Easier.
Yea, worked for me too, and my night sensor still works. No need for cutting, so maybe that is the 'RIGHT' way.
ICrazyChrisI
Postby Stock Solara SEV6 » Thu Apr 22, 2004 7:32 am
I recall the DRL circuit has a resistor in the wire going to the lights to cut the power from them for daytime use. Disconnecting this resistor (or the wire its in series with) would cut the power for the DRL and not affect anything else. I think this is what people are disconnecting under the hood. This seems like the easiest and cleanest way, IMHO
2001 V6 5-speed
Stock Solara SEV6
Postby boneezy » Thu Apr 22, 2004 12:32 pm
theres TSB for all of this guys.. for the total "RIGHT" way.. search it up!
1999 SE-V6 5spd
160,xxx miles
boneezy
Postby ICrazyChrisI » Thu Apr 22, 2004 4:56 pm
miltdoggie wrote:
j0hn19 wrote:theres TSB for all of this guys.. for the total "RIGHT" way.. search it up!
If youre gonna bring up a correct way, post it up.........
Ditto
ICrazyChrisI
Postby TRD MCV20L » Fri Apr 23, 2004 12:36 pm
whiteflash wrote:i trid that gray plug and the night time senser and it didnt work so then this guy went in my car took out under my steering well we found the relay it says DRL on it and then we fixed it from there
can you please tell me how he did this.
TRD MCV20L
Postby all_red » Fri Apr 23, 2004 2:22 pm
Hey TRD MCV20L, First try unpluging the grey plug in the upper left side of the engine bay.. and unpluggin the sensor on tha dash (both the plug and sensor are on the passenger's side) Those will do the job hopefully.
5-speed V6.
TRD Supercharger.
all_red
Postby TRD MCV20L » Fri Apr 23, 2004 2:24 pm
all_red wrote:Hey TRD MCV20L, First try unpluging the grey plug in the upper left side of the engine bay.. and unpluggin the sensor on tha dash (both the plug and sensor are on the passenger's side) Those will do the job hopefully.
ive tried that already. im puzzled because it still works every once in a while
TRD MCV20L
Postby krook » Fri Apr 23, 2004 6:10 pm
keid,
check yo' PM sucka! :wink:
krook
Postby gLok » Sun May 15, 2005 8:26 pm
Hey guys, i was just surfin through here and wanted to post my old DRL disable page. I used the DRL disable TSB to figure it out.
http://www.legacytuning.com/DRL/DRLdisable.htm
99 Camry V6 5 speed - built 1mz +++
90 Integra LS 5 speed - daily beater
http://www.grantscustomrigging.com
gLok
