SolaraGuy.com • View topic - HELP! PLEASE HELP!
HELP! PLEASE HELP!
HELP! PLEASE HELP!
Postby TRD MCV20L » Fri Apr 23, 2004 12:54 pm
someone please help me disable my DRL's. i know that there is many posts about this and ive been to them all. ive pulled the gray plug under the hood and it disabled the DRL's for a while but now. ive even tried krook's plug it in for a few mins method and it still dosent work
whats the best way to fix this for good? ive heard to keep your ebrake up 1 notch or go under the dash and pull somthing.
please help me out. thanks in advance
TRD MCV20L
Postby Stock Solara SEV6 » Fri Apr 23, 2004 1:23 pm
You mean to tell me that you unhooked a wire and somehow the current can find it's way through the air and complete the circuit still? You got to be freaking kidding me. Either fully unhook the wire or use the search function to get the TSB on how to disconnect at the ECU.
2001 V6 5-speed
Stock Solara SEV6
Postby TRD MCV20L » Fri Apr 23, 2004 1:26 pm
Stock Solara SEV6 wrote:You mean to tell me that you unhooked a wire and somehow the current can find it's way through the air and complete the circuit still? You got to be freaking kidding me. Either fully unhook the wire or use the search function to get the TSB on how to disconnect at the ECU.
yes is unhooked and it still works. it has me stumped.
TRD MCV20L
Postby Stock Solara SEV6 » Fri Apr 23, 2004 1:41 pm
Has your car ever been in an accident?
2001 V6 5-speed
Stock Solara SEV6
Postby TRD MCV20L » Fri Apr 23, 2004 1:42 pm
Stock Solara SEV6 wrote:Has your car ever been in an accident?
nope
TRD MCV20L
Postby Stock Solara SEV6 » Fri Apr 23, 2004 2:13 pm
Either the wire is not really disconnected or what you are seeing is not your DRL but really your headlights. The DRL's can't light up if there is no power to them. Plain and simple as that.
Later.
2001 V6 5-speed
Stock Solara SEV6
Postby TRD MCV20L » Fri Apr 23, 2004 2:20 pm
Stock Solara SEV6 wrote:Either the wire is not really disconnected or what you are seeing is not your DRL but really your headlights. The DRL's can't light up if there is no power to them. Plain and simple as that.
Later.
thats what i thought too. but other people on the boards have this problem too
TRD MCV20L
Postby all_red » Fri Apr 23, 2004 2:35 pm
Did you unplug the sensor on the dash??
5-speed V6.
TRD Supercharger.
TRD Short Throw Shifter.
Tokico/Eibach combo.
all_red
Postby TRD MCV20L » Fri Apr 23, 2004 3:17 pm
all_red wrote:Did you unplug the sensor on the dash??
yep ive done that too
TRD MCV20L
Postby Mole » Fri Apr 23, 2004 6:23 pm
some folks have that problem with HID only. not normal halogen.
Postby TRD MCV20L » Fri Apr 23, 2004 11:00 pm
wheres the DRL relay? i couldnt find it :x
TRD MCV20L
Postby TRD MCV20L » Fri Apr 23, 2004 11:30 pm
i need to find the DRL relay so i can pull this
D6 connector, pin 23, EWD PG# 102/96
anyone know where its located? thanks in advance
TRD MCV20L
Postby Yanks0114 » Sat Apr 24, 2004 1:59 pm
Later.
Thats not true. Some people wtih HIDs have reported that DRLS are back on. I believe it has to do with the balast reconnecting the circuit.
Postby esculatus » Sat Apr 24, 2004 6:18 pm
this may be stupid... is your head light lever on the "on" position? lol...
esculatus
Postby TRD MCV20L » Sat Apr 24, 2004 9:26 pm
esculatus wrote:this may be stupid... is your head light lever on the "on" position? lol...
yes
TRD MCV20L
