SolaraGuy.com • View topic - is it possible to drive without signal lights on ? *PIX UP*
Postby Solaradude » Tue Apr 27, 2004 8:21 pm
I asked tweazy about this on camryman.org (way back in the day) and he said that his signal bulbs sorta went out and they only comes on when he turns on the signal....I think it looks 23983298 better to drive without them on. (with headlights on of course)
Solaras dont have side markers and I know for bmw e46s all you have to rewire the headlight wires to the sidemarkers and the signal lights wont light up when the headlights are on.
any suggestions?
Steve :evilbat:
Solaradude
Postby Mole » Tue Apr 27, 2004 8:34 pm
mine light up when the headlights come on.
they blink when i signal too.
Postby Solaradude » Tue Apr 27, 2004 9:00 pm
The Bogey Man wrote:mine light up when the headlights come on.
awww geez, i wish i could show you the pic.
tweazy's solara signal lights didnt light up when the headlights are on and it looks pretty cool
Steve :evilbat:
Solaradude
Postby Dan » Tue Apr 27, 2004 9:18 pm
Easy
My signal light is off when my headlight is on. when I signal, it signal. All you do is look at the signal bulb and tape up one black connecter thingy on the bottom of the bulb. Theres two on the bottom of the bulb. make sure you tape out the right one. one of them lights up when your headlight is on and the other one is when you signal. You have to make sure tape up the right one.
I also ask Tweazy way back then too. He told me, it just way out. I figure out a way to disconnect it. That was the easiest way. I couldn't find anything that match my purple HIDs. Hope this helps.
Dan
Postby Solaradude » Tue Apr 27, 2004 9:23 pm
Dan wrote:Easy
dan.....u r a pimp! but one quesiton, what kind of tape did you use? electrical tape or just the regular one?
woultn it burn out the tape?
Steve :evilbat:
Solaradude
Postby Dan » Tue Apr 27, 2004 9:53 pm
I used electrical tape. I been using it for over a year now and it's been fine. I just checked on it rite now and it looks fine to me. It should take you no more than 5 mins. very easy.
Dan
Postby Solaradude » Wed Apr 28, 2004 12:14 am
6000k HIDs here i come!
x0x0s to u dan
Steve :evilbat:
Solaradude
Postby Fenix » Wed Apr 28, 2004 7:42 am
Hummm, i thought it could be done without any problem.
Just replace your signal light 1157 with 1156 bulbs, and you're set. The other day I accidently put the 1156 in my signal lights, and didn't see them ON at night but worked as I signaled.
I had the setup for weeks before switching back to the 1157 because I want to see my signal light ON when using the remote starter.
Just try it, you'll be amazed.
R.I.P baby.
Here come the black on black 5spds. New era....
Fenix
Postby Jai_Jai_Binks » Wed Apr 28, 2004 8:29 am
Fenix: Any things lights up on the instrumt cluster indicating burnt out lights? (ie. rather than using a dual fillament bulb...just use the single fillament bulb) . Anything wrong with that set up?
I ask cus i tried going the single fillament route on my corners..and my lights became hyper flashers (yeah they didn't light with the headlights - but did with indicators - I didn't like them flashing at a higher rate). Hence i went back. Fenix: can u confirm that your indicators work normally..and that your parking corner lights don't light up??? thanks
Postby Fenix » Wed Apr 28, 2004 9:14 am
Jhbhatia,
Nothing lighted up in the cluster. Everything was fine, the flash was normal.
Nothing was wrong, but at that time I thought it was illegal. It was kinda cool, maybe I should go back to it :D .
R.I.P baby.
Fenix
Postby MalBandito99 » Wed Apr 28, 2004 12:12 pm
Good thread. 8)
MalBandito99
Postby Solaradude » Wed Apr 28, 2004 1:04 pm
MalBandito99 wrote:Good thread. 8)
damn straight :evilbat:
Solaradude
Postby SolaraT » Wed Apr 28, 2004 3:16 pm
Yep...I guess it's to easy for a DIY. a? I guess this would be especialy good when running foglights with no signal lights on! I like that look when its dusk/dawn.
2007 VW GTI
SolaraT
Solaraguy need mo power guy
Postby PEITRUS » Fri Apr 30, 2004 10:33 pm
solarat wrote:Yep...I guess it's to easy for a DIY. a? I guess this would be especialy good when running foglights with no signal lights on! I like that look when its dusk/dawn.
how about running the foglights alone, or even foglights with signal lights only and no headlights? how would you do that?
PEITRUS
Postby SolaraT » Sat May 01, 2004 5:18 am
Well if you disable the corners to only run when signaling then if you keep the switch to the first click only the fog lights and corners turn on. After the next click the headlights come on? No? I could be dreaming or getting confused with my wifes old alero.
2007 VW GTI
SolaraT
