SolaraGuy.com • View topic - intake installed
intake installed
intake installed
Postby Solaradude » Fri Apr 30, 2004 10:53 pm
after a couple of phone calls to solarat....it happened. 8)
I really cant tell any difference but I do feel like I've lost some torque in the 20-40 mph range, im not sure about the high end though but it still sounds cool when I start the engine 8)
The way I drive my 4 banger....man, I drive it like a V6. I literally floor it all the time and shift at around 3.5 or 4k rpms. Now with the intake, I've been gettin this "RICEY" BRROOM sound out of it when I drive it. Is this normal? Maybe I should drive my car a little bit less wrecklessly. 8)
now I just have to punch holes in the intake tube so I get that "blow-off valve" shhhhhhhhhhhh noise :drinking:
Steve :evilbat:
Solaradude
Postby dan99solara » Sat May 01, 2004 9:03 am
yes its normal to get the broom sound. thats how all short rams sound. i hope youre joking about the punch holes into the intake tube because you will be letting unfiltered air into your engine.
1999 Solara V6 5spd 155k miles
TEIN springs. thats it.
dan99solara
Postby SolaraT » Sat May 01, 2004 9:36 am
Man you just loco Steve. Clean the filter and it will help you out. It's DIRTY as heck! The filter should look blue and it's almost black
Don't punch any holes anywere! That would be ricey and damage your car.
short Intake alone is not going to give dramatic hp gains anyway especialy since the rest is stock.
If you were to do a dyno with the hood closed even the numbers would be higher than stock.
2007 VW GTI
SolaraT
Solaraguy need mo power guy
Postby prowlerartist » Sat May 01, 2004 11:11 am
does the cold air intake with that extension sound the same as the shot one
prowlerartist
Postby SolaraT » Sat May 01, 2004 11:27 am
It depends on what kind of exaust system you are running. With Stock exaust system the CAI sounds real deep. Almost double from sort ram.
Once you have better flow to exaust the sound evens out.
v6 with S/C people have said that they hear the S/C whine louder.
2007 VW GTI
SolaraT
Postby Solaradude » Sat May 01, 2004 11:31 am
fine fine i guess no holes for now
Steve esta loco
Steve :evilbat:
Solaradude
