SolaraGuy.com • View topic - whats the difference between drain & refill and flushing
Postby Solaradude » Fri May 07, 2004 3:00 pm
im pretty sure i got my atf flushed at like 45k.....but im just curious, whats the difference?
Steve :evilbat:
I will bankroll your poker career!! visit www.instant-bankroll.com
Solaradude
Postby bkp_duke » Fri May 07, 2004 3:22 pm
In a flush they (mechanic, etc.) hook up a pump with ATF and flush out the old ATF sitting in the torque converter (it won't come out with just a drain).
I'm too cheap to pay someone to do this so I just drained and refilled. Drove the car 2 miles. Then drained and refilled again. That will get 98% of the ATF out of the torque converter.
bkp_duke
bkp_duke
Re: whats the difference between drain & refill and flus
Postby geminimouse » Fri May 07, 2004 4:18 pm
Solaradude wrote:im pretty sure i got my atf flushed at like 45k.....but im just curious, whats the difference?
Steve :evilbat:
flushing is running the fluid thru it, while draining at hte same time.
drain & refill is draining until empty then refill it.
08 Accord Coupe
99 Solara Sold on 7/7/07
geminimouse
Postby SolaraT » Fri May 07, 2004 5:04 pm
Go for the more expensive one...Drain..(Toyota dealer) It's like $15.00 difference.
Yeah the drain they actualy drop the pan and clean the gunk out w/filter cleaning or replacement if needed.
The other is just plug and flush like they said. Don't forget to ask about the tourque converter drain.
2007 VW GTI
SolaraT
Solaraguy need mo power guy
