SolaraGuy.com • View topic - Door jamb plastic
Door jamb plastic
Door jamb plastic
Postby sunrise_solara » Sun May 09, 2004 7:15 pm
How could I safely remove the plastic pieces that wrap around the door jamb and lower quarter panel. Mine are turning brown and look very bad on my white car. Should I replace them? I can't see any use for them.
David
sunrise_solara
Re: Door jamb plastic
Postby 1st Gen Sol » Sun May 09, 2004 9:23 pm
sunrise_solara wrote:How could I safely remove the plastic pieces that wrap around the door jamb and lower quarter panel. Mine are turning brown and look very bad on my white car. Should I replace them? I can't see any use for them.
David
Wussup Bro....I just took those pieces off my car it it left a stain on my paint.......but it came off after using a rubbing compound and then giving it a nice wax......There's basically no need for those pieces, it just comes as a protectant from the factory.......I used a heat gun to take mine off and I think that works best.......just don't keep it on the plastic too long or your paint is gonna come off with it....Good Luck Man 8)
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby Jai_Jai_Binks » Tue May 11, 2004 9:25 am
David
Are you referring to the side on the body and not the door right? I remember mine were discolored and i just clay bar'ed them clean..they because white again!
Edit: my stickers were still stuckhard...dirt was on top of the sticker...hence the claybar worked...since your sticker is loose...don't know??
Last edited by Jai_Jai_Binks on Tue May 11, 2004 12:58 pm, edited 1 time in total.
Postby sunrise_solara » Tue May 11, 2004 11:07 am
^Yeah, that's them...Problem is, I think they're coming unstuck (especially the passenger side) and the discoloration is from the dirt trapped underneath. I could be wrong...Hell, I'll try the clay bar and see if it does any good. Thanks
David
sunrise_solara
Users browsing this forum: No registered users and 94 guests
