SolaraGuy.com • View topic - wood trim removal help? Please =]
Postby Jackass-Jeff » Tue May 11, 2004 8:33 am
How are the wood pieces held in? Are they just clips or are they screws?
Any help would be appreciated =]
Thanks!
1GR-FE ftw!
Jackass-Jeff
Postby i20solara02i » Tue May 11, 2004 10:12 am
clip
i20solara02i
Postby WTF?? » Tue May 11, 2004 10:14 am
hsakuragi and trdkamuri510 was talking about this at the last meet 04-17-04...
hsakuragi removed and repainted his trim so im sure he'd be glad to help you on this... but from what I heard trdkamuri said, for the doors, the "proper way" to do it is to remove the whole door panels and then remove the clips from the inside since itll be a BiyaCh if clips are broken.... the ones on your dash... im clueless sorry jeff
Retired... its been fun Image
WTF??
Postby Grazi07 » Tue May 11, 2004 10:40 am
If you're talking abt the decal kit, heating it up might help. I know thats how you apply the adhesive, so maybe it'll help in taking it off.
Team Nex-Gen: The new breed of speed!
Check us out at www.teamnexgen.net
Grazi07
SolaraGuy UConn Guy
SolaraGuy UConn Guy
Postby Mole » Tue May 11, 2004 10:52 am
you rip it from dash and break back with knee like SO!
-el asso wipo from mad tv.
i accidentally pulled the passengers side off on accident. pretty easy to pop out.
Postby Jackass-Jeff » Thu May 13, 2004 11:28 pm
thanks! I'm replacing my yellowish nasty-looking gen 1.5 wood w/ the gen 1 dark rich colored wood =D
1GR-FE ftw!
Jackass-Jeff
Postby Hsakuragi » Fri May 14, 2004 12:29 am
Grazi07 wrote:If you're talking abt the decal kit, heating it up might help. I know thats how you apply the adhesive, so maybe it'll help in taking it off.
no he's talking about the door trim
Hsakuragi
Re: wood trim removal help? Please =]
Postby Hsakuragi » Fri May 14, 2004 12:30 am
xRAVExBoIx wrote:How are the wood pieces held in? Are they just clips or are they screws?
Thanks!
yes..the PROPER right was removing the doors, i take the un professional right..i just use glue gun to make it stay..
Hsakuragi
Postby FLASH » Fri May 14, 2004 5:08 am
i ripped mine out to paint them as well, they were clipped and glued in so i literally broke them out and broke them back in.
==FLASH==
(Sister's) 2011 "Pink Prius"
FLASH
Postby Jackass-Jeff » Fri May 14, 2004 7:08 am
FLASH wrote:i ripped mine out to paint them as well, they were clipped and glued in so i literally broke them out and broke them back in.
lol
1GR-FE ftw!
Jackass-Jeff
Postby Solorange » Wed Mar 26, 2008 5:11 pm
Just removed the wood trim off my car today. The dash pieces were very easy to remove. You just have gently pop them off with a flathead screwdriver. Now the door pieces are easy also, but just to save you guys some time you do not have to remove your door pieces because its pointless. These pieces are plastic welded in place. Toyota melted the tabs to the backside of the door. So you just have break all the clips to get it out. As far as getting them back on I haven't got that far yet but Im planning on using that 3m double sided tape to stick it back on.
Postby Donnie » Wed Mar 26, 2008 5:19 pm
I did mine and yeah they were plastic welded. Maybe I was lucky but when I put them back in the door they popped and held enough so that I used the new super glue that's kinda like a gel and let it set. It takes longer to harden but worked great.
Donnie
trim
Postby NRDriver » Wed Mar 26, 2008 7:27 pm
Solorange wrote:Just removed the wood trim off my car today. The dash pieces were very easy to remove. You just have gently pop them off with a flathead screwdriver. Now the door pieces are easy also, but just to save you guys some time you do not have to remove your door pieces because its pointless. These pieces are plastic welded in place. Toyota melted the tabs to the backside of the door. So you just have break all the clips to get it out. As far as getting them back on I haven't got that far yet but Im planning on using that 3m double sided tape to stick it back on.
i just did this and i used some weatherstripping adhesive on each tab of the door trim.
NRDriver
Postby Jakecallun20 » Wed Mar 26, 2008 7:32 pm
You guys paint the trim, or replacing it with something else? If your painting hows it look? I have considered painting mine black.
Postby nemoxfishy » Wed Mar 26, 2008 7:52 pm
i broke most of the clips too... but its not noticable at all after i glue them bak in.... i used LOTS of dental floss to pull them out... i was scared that the wood trim will break in half if i yanked it out from the ends too hard.... loopng the floss around the trim is the safest thing 2 do....
i have all my wood trim as well as my center dash painted black w/ silver sparkles.... sounds weird but looks nice tho... i'll post some pics up later =]
nemoxfishy
