SolaraGuy.com • View topic - car starting problems
Postby solaraslev67 » Thu May 20, 2004 10:02 am
this only happens on occasion but not seems to be happening more and more....like once a week...
ill turn on my car and then the car will stall out, right away, right when i start the car if i pump the gas it will stay on but soon stall out, once then engine gets warm it runs fine but how can i make this not be a 20 minute problem everytime my engines cold, or like how can i not have this happen anymore?
solaraslev67
Re: car starting problems
Postby Fenix » Thu May 20, 2004 12:15 pm
solaraslev67 wrote:this only happens on occasion but not seems to be happening more and more....like once a week...
I think you need to change your alternator. It seems like your battery doesn't get enough juice from the alternator.
Take your alternator out, bring to the store to exchange for a new one, put it back in, voila.....
R.I.P baby.
Here come the black on black 5spds. New era....
Fenix
Postby Mole » Thu May 20, 2004 12:27 pm
what happens if you just let the car idle?
some earlier posts were about the idler control valve.
i doubt its the alternator since the car stays on when the car is warmed up. the car does not utilize the battery once the car is on. unless you run a system or something.
who knows anything is possible w/ electronics
Stalling
Postby jim@foreignaffairs » Thu May 20, 2004 12:49 pm
This has nothing to do with the alternator, it is probably the IAC valve. This is on the bottom of the throttle body, and they sometimes stick, crap gets into them, try taking it apart and cleaning it out, it should move smoothly. IAC stands for Intake Air Control...it allows the computer to control idle speed.
jim@foreignaffairs
Re: Stalling
Postby Jai_Jai_Binks » Thu May 20, 2004 1:38 pm
jim@foreignaffairs wrote:This has nothing to do with the alternator, it is probably the IAC valve. This is on the bottom of the throttle body, and they sometimes stick, crap gets into them, try taking it apart and cleaning it out, it should move smoothly. IAC stands for Intake Air Control...it allows the computer to control idle speed.
^^ what he said....if you don't want to do it diy...dealerships (or even local shops) do a EFI service...they clean the throttle body and also add the fuel additive to the tank of gas.
Postby SolaraT » Thu May 20, 2004 2:47 pm
Man it can mean so many things...
-Idle speed incorrect.
-fuel filter clogged.
-ignition components damp or damaged.
-faulty emissions systems components (IAC) like Jim said
-Faulty or incorrectly gapped spark plugs.
-faulty spark plug wires.
-vacuum leak in the fuel injections system, intake manifold or vacuum hoses
-Valve clearances incorrectly set.
Check out one at a time starting with the easiest and process of elimination. All this came right off Haynes repair manual for engine stalls. *Notice nothing about the alternator.
2007 VW GTI
SolaraT
Solaraguy need mo power guy
Postby WTF?? » Thu May 20, 2004 4:17 pm
Yeah me and Kondo has recently went thru changing out our IAC's!!! It hella BUGS to see your car start up.. then the idle just DROPS! :evil:
cleaning could possibly the solution, but not in my case... cleaned then replaced :roll:
... THEN that didnt work so had to replace my computer :bad-words:
GOOD LUCK THO :D
Retired... its been fun Image
WTF??
