SolaraGuy.com • View topic - Giving up DIY spark plug change =)
Postby esculatus » Sat May 22, 2004 2:45 pm
I've given up DIY spark plug change. Does anybody know any good shop that will do it for a reasonable price?
Souther Cali area
Thanks in advance.
esculatus
Postby Mole » Sat May 22, 2004 4:16 pm
i know of a home mechanic located in Artesia/Ceritos area.
Postby Solaradude » Sat May 22, 2004 8:10 pm
yea i thought changing spark plugs would be a piece of cake but you need a some sort of special tool to get the spark plugs out. I think I paid 20 bucks to get em installed.
Steve :evilbat:
I will bankroll your poker career!! visit www.instant-bankroll.com
Solaradude
Postby hari-bhari » Mon May 24, 2004 8:05 pm
Solaradude wrote:yea i thought changing spark plugs would be a piece of cake but you need a some sort of special tool to get the spark plugs out. I think I paid 20 bucks to get em installed.
Steve :evilbat:
nooo man, its really easy on the 4 banger, i did it myself. the tool is just a special socket that costs like 5 bucks from autozone or any other similar store. the v6 is harder because three of them are located in the back, but the I4 is very simple, took me 15 minutes. oh yea, and go for denso iridium IK20s, they are nice.
hari-bhari
Postby MaxBoostSolara » Mon May 24, 2004 8:10 pm
so did i buddy... and nice they are
MaxBoostSolara
Postby bassthrive » Tue Jun 15, 2004 7:12 pm
Mineke wants $60 to install plugs on my V6. Is this a ripoff? I didnt tell them about the new wires yet either.
- Paul
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby esculatus » Tue Jun 15, 2004 10:23 pm
shops here wanted 50 and I thought that's already too much. The dealers charges 80
but mine is supercharged so I dont know if that will hinder things a bit.
esculatus
Postby Turbosolara » Wed Jun 16, 2004 12:04 am
usually a mechanic charge 40-60 dollars for one hour labor
Postby Masshole » Wed Jun 16, 2004 6:34 am
I did mine in the V6 and it wasnt' THAT bad. You just need some extensions and a wobbly and some patience to get at the rear ones. Special tool??? You mean the spark plug socket? All tool sets come with one... I don't know if that classifies as a special tool.
40-60 bucks is about right for an hour's labor. You can get some extensions and a u-joint for probably less than that and then you have some useful tools in your arsenal for future work AND the satisfaction of getting the job done yourself. my 2cents
Masshole
Postby bassthrive » Wed Jun 16, 2004 11:51 am
Ive personally done everything for my 60k maintenance - oil change, oil filter, tranny flush, coolant flush, fuel filter, cleaned k&n air filter, pcv valve, new battery, cleaned throttle body - I really do NOT want to do spark plugs. Ill see if i can find a shop that will hook me up for $40, that would be sweet.
- Paul
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby esculatus » Wed Jun 16, 2004 12:12 pm
how did you clean the fuel filter? I thought the fuel filter is in the tank?
and the throttle body? how do u clean that?
esculatus
Postby bassthrive » Wed Jun 16, 2004 9:30 pm
Fuel filter is a replacement part, and its under the airbox.
Go to an auto parts store and buy some throttle body cleaner spray, make sure its ok for fuel injected vehicles. Take off the rubber intake hose going into the throttle body and spray that stuff in there, work the butterfly valve with your hand as you spray to get deep inside. I scrubbed with a toothbrush, then wiped out the nasty black crap with a rag. Go here for a tutorial with pictures... http://www.4x4wire.com/toyota/maintenan ... ttle_body/
Throttle response is nice. It was feeling "sticky" before. Now when I press the accelerator pedal it glides like new.
- Paul
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby esculatus » Thu Jun 17, 2004 12:21 am
nice post! Thanks. You should post the throttle body cleaning in the DIY section. I m sure people will appreciate it.
esculatus
Postby bassthrive » Thu Jun 17, 2004 12:32 pm
Doh! Another shop quoted me $150 labor and that they needed a new intake manifold gasket!
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby somethingcool » Thu Jun 17, 2004 6:12 pm
bassthrive wrote:Ive personally done everything for my 60k maintenance - oil change, oil filter, tranny flush, coolant flush, fuel filter, cleaned k&n air filter, pcv valve, new battery, cleaned throttle body
- Paul
How did you do a tranny flush yourself?
somethingcool
