SolaraGuy.com • View topic - Installing new rotors
Postby groovespacer » Mon May 31, 2004 8:02 pm
I was wondering how difficult it would be to install rotors. Is that a job in which anyone with a decent jack can handle? Or is it for the pros?
groovespacer
Postby 808Camry » Mon May 31, 2004 11:25 pm
If you can change your brake pads, you can do rotors. It's fairly simple. Good luck!
808Camry
Postby swimshady906 » Tue Jun 01, 2004 12:37 am
There are essentially ... 7 nuts you have to remove... 5 of which are lugs :D
02' S2000 Silverstone
swimshady906
Postby redkysolarase » Tue Jun 01, 2004 10:46 am
I'm pretty sure there's 9 aren't there. :-?
redkysolarase
Postby 808Camry » Tue Jun 01, 2004 10:55 am
Yup 9, 5 lugs, and two big ones for the caliper and two smaller ones for something else I believe, the backing plate?
808Camry
Postby adam2562 » Tue Jun 01, 2004 11:39 am
9 is right
Adam - 99 V6 5spd 165k -SOLD
adam2562
Postby MGLax13 » Tue Jun 01, 2004 2:14 pm
MGLax13
SolaraGuy Solara13
SolaraGuy Solara13
Postby Fletch » Tue Jun 01, 2004 6:17 pm
I couldn't get the rotors off without the bolt that pushes them off, they were rusted to the hub pretty bad.
2006 Legacy GT spec.B
Fletch
Postby groovespacer » Tue Jun 01, 2004 6:57 pm
Anyone got links to tutorials on this and for changing brake pads?
groovespacer
Postby swimshady906 » Tue Jun 01, 2004 10:57 pm
I find it easier to take off the two big ass bolts connecting the calliper, leaving it fully assembled just not on the rotor. 7
swimshady906
Postby adam2562 » Thu Jun 03, 2004 2:48 pm
if ur taking off old rotors just bang them with a hammer.. u wont need them anymore...
adam2562
Postby that1mexguy » Fri Jun 04, 2004 1:23 pm
groovespacer wrote:Anyone got links to tutorials on this and for changing brake pads?
Hey man, just yesterday i changed the pads for my 99SE and it's VERY easy (once you figure out what tha hell u r doing). It took me a few more hrs than what it should've, but that's because it was my 1st time (yaaay :bday: ) and i was being extra careful. Also, it helps to read the freaking instructions (not just look at the pics lol :roll: ). I recommend you buy the Haynes manual at ur local PepBoys or wherever u can find one. But if u can aford/find one keep reading (keep in mind this is for a 99 Solara w/4 disc brakes, other models may very)
If all you are doing is replacing the pads, then you'll need to remove two(2) 12mm bolts in the back of the calipers (front wheels) and only one(1) for the back tires. The calipers on the front you have to remove once u take these 2 bolts out and the one on the back tires slides up (u'll see what i mean once you remove that bolt at the very bottom on the back of the caliper). You'll need a C-clamp to move the piston back to make room for the new pads. Then even after installing the new pads, and moving the piston to make room for them, if you cant still get the calipers back in place, keep in mind that the are where the 12mm bolts go, CAN move (that's something i did not find in the instructions and took me almost 2 hrs to figure out!) :x all u gotta do is push them back with ur fingers! Anyway, that's all it is, to change the pads, hope that helps man....
PS. if you are changing the rotors, use these instructions, plus the link provided to you above, and also keep in mind that to remove the rotors, you dont necessarily need to remove the calipers completely. What i did was to use a bungee cord to hold them against the struts as i removed the back rotors (just wanted to do it for the hell of it so that i'd know what to do when i get some Brembos). And to remove the rotors, the 2 bolts in the back are 14mm (not 17 as the instructions said). NOTE: When doing the back wheels, make sure your emergency brake is NOT on (kinda learned that the hard way LOL). Then just pull them out, and if they are too rusty, no need to hammer them, use the same 12mm bolts to screw them in the 2 holes in the rotors, that will separate them from the car and u can easily take them out. I didnt do the rotors in the front due to lack of time, but the instructions from SuperStreet should be able to walk you thru with no problem. Good luck! :D
that1mexguy
Postby sunrise_solara » Fri Jun 04, 2004 6:28 pm
What kind of rotors did you go back with, groovespacer?
David
sunrise_solara
Postby adam2562 » Mon Jun 07, 2004 4:07 pm
i personally love HAWK pads..... never squelled but they were amazing and did good against brake fade...
adam2562
