SolaraGuy.com • View topic - Resetting your timing
Postby swimshady906 » Tue Jun 01, 2004 12:51 am
I found out today that if you have one bank of cylinders misfiring multiple times and the computer decideds to retard your timing that the best way to fix it is start the car pull out your EFI fuse disconnect the ground and leave it off for 2 minutes then reconnect evreything and let the car idle once more for a few minutes. Courtesy of my local toyota tech's.
It worked for now, but well see in 40 miles if that check engine light comes on. :roll:
02' S2000 Silverstone
swimshady906
