SolaraGuy.com • View topic - Emergency brake lever adjustment ???? HELP!!!
Postby that1mexguy » Fri Jun 04, 2004 1:34 pm
Ok, i have the Haynes Manual for my car (99 Solara) and it says that the emergency brake should only click 5-8 times. Mine is going about 10-11 so obviously, it needs to be adjusted. According to the manual, all i have to do is go inside the center console and there should be some bolts i can easily adjust to get the lever 5-8 clicks. Well guess what, i've removed the damn console in the middle and there is NOTHING close to what's in the manual. The manual is for Toyota Cmary 1997-2001 to include Solara, Avalong and Lex ES300 so I know i got the right now. Does any1 out there knows how to get the emergency brake lever adjusted to the correct settings for a 5 speed 99SE Solara??? pls?? :roll:
that1mexguy
Postby Solaradude » Fri Jun 04, 2004 1:40 pm
retighten your parking cable...this one shop quoted me at 70 bucks :(
I will bankroll your poker career!! visit www.instant-bankroll.com
Solaradude
Postby SolaraT » Fri Jun 04, 2004 2:34 pm
^^ Thats 70 bucks you could save!! Real easy!!
For the drums and disk it's the same. Adjust from the outside with a "Brake adjustment tool" but you can use a flat head screwdriver. Go to page 9-13 and you will find how to do it. See illustration 5.6 and 5.6c "rotate the adjuster wheel in a clockwise direction"
If you have trouble give me a ring and I can give more info.
Later...
2007 VW GTI
SolaraT
Solaraguy need mo power guy
Postby that1mexguy » Fri Jun 04, 2004 3:03 pm
Actually i was able to figure it out. After removing the console, follow the lever and you can see the cable at the bottom. At the very top of the cable (behind the lever) there are 2 nutz, one on top of the other. The nut at the bottom is what needs to be adjusted. So now I'm at 6-7 clicks, yaaaay me!! :drinking: :bday: :drinking: :bday: :drinking:
that1mexguy
Postby pythonjosh » Sat Jun 05, 2004 3:27 am
Solaradude wrote:retighten your parking cable...this one shop quoted me at 70 bucks :(
I'll do it for $50 :drinking: :drinking:
pythonjosh
Postby that1mexguy » Sat Jun 05, 2004 6:28 am
Heck, all i need is a 12 pack! (after doing the work of course) LOL
that1mexguy
Postby SolaraT » Sat Jun 05, 2004 10:32 am
Dang! 12! I'll pass out! 6 for me! :drinking: :lol:
2007 VW GTI
SolaraT
Postby that1mexguy » Sat Jun 05, 2004 10:59 am
i didnt say i'd drink them all at the same time my friend.. .but a 12 pack will save me a trip to the store the next day :drinking:
that1mexguy
Postby Solaradude » Sat Jun 05, 2004 4:47 pm
beer will make you fat....too much carbs :(
anyway, thanks to solarat i finally got my parkign brake adjusted. it was thte shiznit!
Steve :evilbat:
Solaradude
Postby trdkamuri51o » Sat Jun 05, 2004 10:46 pm
you could drive real fast in reverse then pull up the brake
SELF ADJUSTING MY FRIENDS (well if you have drums)
a little secret from camryman.org
trdkamuri51o
Postby that1mexguy » Sun Jun 06, 2004 5:10 am
Solaradude wrote:beer will make you fat....too much carbs :(
you obviously havent seen me! LOL :drinking:
Solaradude wrote:anyway, thanks to solarat i finally got my parkign brake adjusted. it was thte shiznit!
Steve :evilbat:
you have drums or 4 disc brakes?
that1mexguy
Postby SolaraT » Sun Jun 06, 2004 7:42 am
(mexguy) - he got disk, but it also has that same opening in the driver side rear axle to adjust. He found another way via the center councel.
2007 VW GTI
SolaraT
Postby Solaradude » Sun Jun 06, 2004 11:43 am
solarat! mines a 4 banger!!
Solaradude
Postby SolaraT » Sun Jun 06, 2004 11:53 am
yeah it makes no difference. same location.
2007 VW GTI
SolaraT
Postby DatSRBoi » Mon Jul 12, 2004 11:45 pm
Dang I never knew that..DANG now ima need to do mine too..its like 11 clicks to hold and if driving..11 click and the car still going..darn 5 spd hahaha
