SolaraGuy.com • View topic - tires width
tires width
tires width
Postby Benji668 » Sun Jun 06, 2004 7:14 am
I currently have sets of 225 45 x 17 on my Solara. When I look from the back, tires width look too narrow on a big car like ours in my opinion. How wide of a tire size can we go up to without any major modifications? It looks really musculine when I look at those BMWs with sets of 255 on it.
Benji668
Postby that1mexguy » Sun Jun 06, 2004 7:20 am
i think 235's is the most u can have without any modifications.
that1mexguy
Postby SolaraT » Sun Jun 06, 2004 7:35 am
^ yep 235
I got 235.
Has anyone tried 245?
2007 VW GTI
SolaraT
Solaraguy need mo power guy
Postby swimshady906 » Sun Jun 06, 2004 8:01 am
Hey solarat what kind of offset do you have and for that matter springs/ struts? Ive got 235's and on the highway when i hit a big enough bump it will make a scraping sound only from the right front. Any ideas?
02' S2000 Silverstone
swimshady906
Postby SolaraT » Sun Jun 06, 2004 8:11 am
+38 offset
235/40/18
18x7 rim
Springs: Vogtland
Struts: Tokico
Probably on that side the fender well is dipped lower then the other side. OR your strut is going out on that side. Try to look for any marks of were its scraping and compare it to the other side.
2007 VW GTI
SolaraT
Postby Benji668 » Sun Jun 06, 2004 9:21 am
Hey guys, thanks for for your time of replying. BTW, if I do decide to go for wider sets than 235. What kind of modification do I need?
Benji668
Postby MalBandito99 » Sun Jun 06, 2004 10:19 am
Spacers, and you will thus stick the wheels outside the side of the car's body. I think +3 is allowable for maintaining performance of the vehicle as intended, but after that it is custom work that cannot be guaranteed to be good for your car. Hope you have a good shop to work on this, its not as easy as it seems.
MalBandito99
Postby SolaraT » Sun Jun 06, 2004 11:47 am
ooo custom wide body kit! that would be off the hook!
2007 VW GTI
SolaraT
Postby Ford_Fixorrepairdaily » Sun Jun 06, 2004 12:21 pm
you can fit 19x8.5 on solaras. but you have to roll back the fenders and get a damper coilover suspension.
Postby Benji668 » Sun Jun 06, 2004 2:04 pm
ford_FixOrRepairDaily wrote:you can fit 19x8.5 on solaras. but you have to roll back the fenders and get a damper coilover suspension.
I heard of that terms "roll back the fenders" alot, but how do they actually do it? And does the rim be sticking out the body alittle if using 19 x 8.5? And what size of tires can be fit on that size of rims? I just want to get more better understanding in this topic. Thanks in advance!
Benji668
Postby SolaraT » Sun Jun 06, 2004 2:52 pm
225 or 235 can fit on those. depending on offset.
-If they rub the strut then you need spacers.
-Rolling back fenders is to clear away the part were the tire rubs the fender. You could cut or push them away (Rolling).
2007 VW GTI
SolaraT
Postby Astro » Mon Jun 07, 2004 9:10 am
How would your turning radius be with 235? If you went 245 you probably couldn't make a good u-turn.
Larry
Postby Jackass-Jeff » Mon Jun 07, 2004 9:23 am
true!! Then you can go pretty damn wide!!!
1GR-FE ftw!
Jackass-Jeff
Postby i20solara02i » Mon Jun 07, 2004 1:32 pm
yep wide :drinking:
i20solara02i
Postby townboy2 » Tue Jun 08, 2004 9:02 am
i don't have a good u turn with 225 in front on my TRD wheels... maybe i should have like 215 on front and 235 on back like those rear wheel drive... :angel:
86 RX-7 crashed
94 MX-6 I4 donated it
93 MR2Turbo sold
00 Solara SLE
86 MR2 N/A FREE from a friend... DONATED too
2007 Nissan Altima Hybrid
townboy2
