SolaraGuy.com • View topic - what rpm do you manual drivers shift at
Postby hari-bhari » Sun Jun 06, 2004 2:39 pm
just test drove a v6 manual today (Woohhoooo). it was 2001 se v6, silver, charcoal interior, w/ sunroof. btw i noticed in the 2001 there is an option for 'mid' along with bass and treble on the stereo, whereas in my 2000, theres only bass and treble. anyways, i noticed that for decent acceleration, i was shifting around 3000 rpm, which struck me as a bit odd. in our 95 avalon, with the same engine, i feel the same amount of acceleration by letting it shift at 2200-2300 rpm, and its an automatic. any ideas why this is? also, when you guys are cruising 80 in 5th gear, what rpm is ur engine at? do manuals have cruise control? sorry bout all the questions, thanks in advance.
hari-bhari
Postby thealkimo » Sun Jun 06, 2004 2:52 pm
i usually shift around 3300-3500 in my 5spd i4...it also has cc but i hardly use it
thealkimo
Postby Rudy » Sun Jun 06, 2004 2:54 pm
yeah, i have cruise control in my 99.
I normally shift at about 5800 :evilbat: . ahah, just kidding, but in normal driving i shift at about 2500-3000.
and i'm at about 3k at 80 mph i think?
99 Solara V6 5SPD
Rudy
Postby hari-bhari » Sun Jun 06, 2004 2:59 pm
Rudy wrote:yeah, i have cruise control in my 99.
see thats weird. i donno why the avalon shifts at such low points, and i still get the same amt of acceleration. and in my I4 right now, im at 3000rpm going 80mph. Its a weaker engine, and theres one less gear, and still has the same rpm as the v6 5spds. why is this???
hari-bhari
Postby Rudy » Sun Jun 06, 2004 3:09 pm
i think your 4th and our 5th are almost identical, I dont know much about transmissions, but they're both overdrive gears.
99 Solara V6 5SPD
Rudy
Postby dan99solara » Sun Jun 06, 2004 9:19 pm
automatics have overdrive
1999 Solara V6 5spd 155k miles
TEIN springs. thats it.
dan99solara
Postby Rudy » Sun Jun 06, 2004 9:27 pm
dan99solara wrote:automatics have overdrive
haha, point proven.
99 Solara V6 5SPD
Rudy
Postby all_red » Sun Jun 06, 2004 9:53 pm
It really bothers me to see that needle at 3K when crusing at 80MPH whereas my friends' V8 Camaro is at 1.5K in 6th gear. :evil:
5-speed V6.
TRD Supercharger.
TRD Short Throw Shifter.
Tokico/Eibach combo.
all_red
Postby eugene5786 » Sun Jun 06, 2004 10:37 pm
heh, my friend used to have a 95' pontiac bonniville. at 80 it would hold a little above 1200 rpm. that same day his antifreese leaked into his engine. that same day i got my solara. anyway it stayed at the rpm because the car had power suspension. at those speeds it actually helps
eugene5786
Postby Fletch » Wed Jun 09, 2004 6:17 pm
It doesn't matter that you are at 3000RPM at 80, I still get around 25 mpg going that fast. Honda's are bad about being wound up in 5th gear crusing speed also, but they get good mileage.
2006 Legacy GT spec.B
Fletch
Postby SolaraT » Thu Jun 10, 2004 3:45 am
So we pretty much shift @ 2.5 or 3k for each gear?
i.e. 1st 2.5k SHIFT
2nd 3k SHIFT
3rd 3k SHIFT
4th 3k SHIFT
5th
How high RPMs has one shifted through the gears?
2007 VW GTI
SolaraT
Solaraguy need mo power guy
Postby Jai_Jai_Binks » Thu Jun 10, 2004 8:28 am
So hari: did you sell your 5s already.....
Postby Astro » Thu Jun 10, 2004 8:54 am
I generally shift around 3k. But, when I'm racing I sometimes go up to around 5k. I noticed the s/c really kicks in at higher RPMs.
Larry
Postby esculatus » Fri Jun 11, 2004 4:11 pm
my s/c auto shifts at 5.9~6K 3 gear when I really step on the pedal and won't let go.
is that normal?
esculatus
Postby that1mexguy » Fri Jun 11, 2004 4:19 pm
I got a 5-sp V6 99SE and according to the manual, we are to shift to 2nd after 15mph, then to 3rd at 30mph, to 4th at 40mph, and to 5th at 45 mph. I personally have to shift at higher speeds because of so many damn hills here in GA, but i'd say 3-3.5K rpms sounds about average, or maybe less if going down the hill :drinking: cheers!!
that1mexguy
