SolaraGuy.com • View topic - Burning oil
Burning oil
Burning oil
Postby solrchrgd » Mon Jun 07, 2004 11:10 am
Any suggestions on what it might be?? I don't have any smoke coming out but there is black residue inside the exhaust tip. I am thinking the piston rings are worn. I only have 22000 miles too.
Thanks
Bryan
solrchrgd
Postby SC V6 » Mon Jun 07, 2004 11:13 am
how much boost are you running? u may have a cracked piston land.. take the intake hose coming off the valve cover, and see if air is pusting out that tube, or sucking in..
Sucking in = vaccume
pushing out = blow by/ piston ring/piston problems = ouch
SC V6
Stock boost
Postby solrchrgd » Mon Jun 07, 2004 11:24 am
I am only running 4psi. I will give your suggestion a try and post the results.
Thanks for your help
Bryan
solrchrgd
Postby redkysolarase » Mon Jun 07, 2004 11:45 am
I have black residue inside the tips of my exhaust but I'm not s/c'd. I haven't really taken it into mind that much. The car keeps oil pressure very well and doesn't leak any. I'm due for an oil change right now and it's still full or it's very close. Don't really know, haven't checked it this week.
redkysolarase
Postby Turbosolara » Mon Jun 07, 2004 12:47 pm
I think that's normal. all the exhaust will have some carbon deposit due incomplete burn sometimes.
Postby SolaraT » Mon Jun 07, 2004 1:41 pm
^ hells yeah. I got complete black residue on my new Greddy 4" exaust tip after only 1 month. No S/C or v6.
2007 VW GTI
SolaraT
Solaraguy need mo power guy
Postby hari-bhari » Mon Jun 07, 2004 7:16 pm
black residue is normal b/c of carbon buildup. however greasy or wet black residue is NOT normal, this indicated a problem. but if the residue is fine and dry, then you're fine.
hari-bhari
Postby Fletch » Tue Jun 08, 2004 9:30 am
Did you check the actual oil level on the dipstick? Then you'll know if you're actually burning oil. I burn 1 quart every 2500-3000 but it's not a huge deal at 112k miles.
Most people with high flow mufflers or cat back exhaust have carbon all over the back of their car if you don't wash it frequently.
2006 Legacy GT spec.B
Fletch
Postby redkysolarase » Tue Jun 08, 2004 10:44 am
Fletch wrote:Did you check the actual oil level on the dipstick? Then you'll know if you're actually burning oil. I burn 1 quart every 2500-3000 but it's not a huge deal at 112k miles.
If you're talking to me Fletch then yes I did check it. I did today as matter of fact. I'm 50 miles over my next change date and it's still full. My car just has a little over 62K though. Getting the oil changed this weekend though so it won't matter.
redkysolarase
