SolaraGuy.com • View topic - Engine light
Engine light
Engine light
Postby Bravefan » Fri Jun 11, 2004 9:11 pm
the engine light on my car will not shut off. had a friend test it. does anyone know what code 0130 is? and do you know how to fix it? thanx
Bravefan.
Bravefan
Postby pythonjosh » Sat Jun 12, 2004 12:11 am
If your friend tested it, can't he tell you what's wrong? Is the car driving any differently? It's always good to check all your fuses too.
Josh
pythonjosh
Postby bkp_duke » Sat Jun 12, 2004 4:08 am
P0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
Had the same thing go out. There are 3 O2 sensors on the V6 to the best of my knowledge. One per engine exhaust manifold and one after the cat (please correct me if I am wrong, it's been a while).
The front O2 sensor is REALLY easy to replace. It's just below and to the right of the spark plugs. The other front O2 sensor is on the back of the engine near the bottom. You can do it yourself, but it takes a while to get your arm down the firewall and reach it. I've never done the one near the cat, but I hear it sux. You have to remove a seat to get to it.
bkp_duke
Postby Bravefan » Sat Jun 12, 2004 8:17 am
where can I get a replacement?
Bravefan
Postby bkp_duke » Sat Jun 12, 2004 10:11 am
I would recommend OEM (toyota dealer). Go to them w/ the code and if they are nice (like the dealer here), they will tell you exactly which sensor it is. Mine was about $135 w/ tax. You can probably get one at autozone for ~$90, but i've always been suspicious of the quality of aftermarket parts.
bkp_duke
Postby Bravefan » Sat Jun 12, 2004 10:58 am
thank you
bkp_duke
Bravefan
Postby whiteflash » Sat Jun 12, 2004 2:38 pm
O2 sensors a exhausts worst enemy ahhhh that annoying check engine light!!!
Injen w/CAI Extension
Vogtland Springs
Tokico Struts
Custom Full exhaust
TWM Shortshiftter
8000K HID Kit
whiteflash
Postby Bravefan » Mon Jun 14, 2004 6:27 pm
how do I know which one is bad if I wanted to do it myself?
Bravefan
Users browsing this forum: Google [Bot] and 9 guests
