SolaraGuy.com • View topic - what do I have to do to fit 18"s and lower my car?
Postby randy_1651 » Sun Jun 20, 2004 9:45 am
do i need struts and springs or just springs what is the differnce between 18x7.5 and 18x8.5 also waht is the bolt pattern that i would need??
thanks
randy_1651
Postby MGLax13 » Sun Jun 20, 2004 10:17 am
You can do just springs, but the results will not be favorable. Stock struts will wear out very quickly (I've heard about 5000 miles) and the ride will be very bouncy. 1As far as the 8x7.5 and 18x8.5, 18 is the wheel diameter in inches and the 7.5 and the 8.5 is the wheel width in inches. The bolt pattern is 5 lug by 114.3 millimeters (5x114.3, also known as 5x4.5 in inches). Your best bet for springs are either vogtland, tein or eibach and for the struts, most here have tokico blue struts. You can also go with coilovers made by a few companies like tein and JIC, but that will set you back a considerable ammount more, but it's worth it is you are looking for something that is adjustable in both height and dampening force
MGLax13
SolaraGuy Solara13
SolaraGuy Solara13
thanks
Postby randy_1651 » Sun Jun 20, 2004 10:38 am
thanks
randy_1651
