SolaraGuy.com • View topic - Power source
Power source
Power source
Postby MGLax13 » Tue Jun 29, 2004 9:18 am
Are there any power sources towards the back of the car that are on only when the ignition is in the accy or on position? I'm asking because I plan on hard wiring two deck strobes in my rear window. I already have the front strobe wired into my cigarette lighter. I could run them both to the front of the car and wire them into the other cigarete lighter, but I rather find something a little closer. Any help is appreciated, thanks.
MGLax13
SolaraGuy Solara13
SolaraGuy Solara13
Postby Mole » Tue Jun 29, 2004 10:25 am
not any that i know of.
you're going to need to get a power source from the front, run a wire under the carpet to the rear.
Postby Yanks0114 » Tue Jun 29, 2004 2:01 pm
TRDmole is correct. There are no power sources towards the rear. Also I wouldn't tap any of the other lines already run such as light bulbs.
Run a new line from the fuse box. You can also run it down the side of the car
Postby MGLax13 » Tue Jun 29, 2004 11:15 pm
sounds good, thanks guys. I'll just run it with all the wires from my system.
MGLax13
SolaraGuy Solara13
SolaraGuy Solara13
Postby MGLax13 » Fri Jul 02, 2004 11:26 am
Another question, when you say run it from the fuse box, what specifically do you suggest I run it from? I have my front light wired into my power outlet (not the cig lighter) in the front, should i now find the wire that goes from the fuse box to the cig lighter and tap into that?
MGLax13
SolaraGuy Solara13
SolaraGuy Solara13
